Question about Proform 785 Treadmill
Error message E21 - Proform 785 Treadmill
Posted by eviletomatoh on
John Mazmanian
    President:
  • Proform Master
  • 832 Answers
E21 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E21 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E21 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor shroud off.
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
On this next step do not step on the treadmill when you press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small black square with a white center and is located near the three small speed wire connections labeled H, W, & L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing, press the Stop key once and remove the safety key.
If the motor does not run, test the motor but first unplug unit then unplug the two leads ( Red and Black ) that is connected to the Motor Control Board.Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. Then Motor Control Motor will need to replaced
Posted on May 21, 2010
How to fix error e21 with my toshiba electric washing machine AW SD130SS. It washes only. No rinse , no spin.
YOUR LID SWITCH IS GOING UPSET
CHECK YOUR DOOR LOOK AND UNDER SWITCH WIRE IS OK
Oct 06, 2017 | Washing Machines
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux Kitchen Ranges
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Error message e21. Bosch dishwasher
My mom had the same issue with her fancy bosch dishwasher! It ended up being a hose, if I remember correctly. Her problem also took two repair trips, I know for sure it was not a new motor issue. I would have someone check the hoses and the electrical panel.
May 28, 2013 | Bosch SMS68M02AU Dishwasher
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
Jan 08, 2009 | Office Equipment & Supplies
Proform 785 Treadmill Logo
2,884 people viewed this question
Top Proform Exercise & Fitness Experts
Marvin
Marvin
john h
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
