Question about Hayward SAND FILTER, PRO SERIES
Hooking up filter to pump and pool
How to hook up pool line, flush line and return lines on a Hayward sand filter pump S180T
Posted by memah6 on
Jessica Harwell
  • 640 Answers
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
Hello! When I first hooked my pump up it blew sand into the pool...now everytime i turn the pump off then back on it blows sand into the pool....what can be the problem
That sounds like your pool filter has backpressure. It is usually caused by air in the lines. You most likely have a crack somewhere in your system. Check the lines, connections, etc for cracks.
Jul 24, 2011 | Hayward SAND FILTER, PRO SERIES
I have an above-ground Hayward sand filter that I'm trying to hook up. I can't remember how to connect the hoses and have been trying to find a diagram (photo) that shows. Can you help?
If you look closely at the plastic near the threaded ports you will see Pump, Return and Waste. Pump is the hose coming up from the pump discharge, return goes back to the pool or to a heater or other accessory if you have one and waste is the backwash line.
John
May 03, 2011 | Hayward SAND FILTER, PRO SERIES
Hooking up five hoses to my hayward pump/filter
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
My new Hayward Pool Sand Filter won't backwash.
Hey!
Mine was doing the same thing. I had the hoses switched up. I had the hose from the pump connected to the port marked RETURN (on the Hayward vari pump valve). Not good! I also had the return line hose (from pool) connected to the port marked pump. It happens! The problem is I tried EVERYTHING ELSE before I found my error. This includes a trip to Leslie's to buy a brand new multi port valve (good thing they have a return policy) AND changing out my relatively new sand in the filter AND taking apart the vertical tube and each individual flange at the bottom to clean them out. Please check your hoses FIRST if it won't backwash! By the way...I've been a pool owner for 17 years. I think my experience worked against me since I didn't recheck my work at setup.
NOTE:
It might SEEM like your filter is working because you get suction at the skimmer and water rushing thru the return line into the pool. It's not working if your lines are backwards like mine were! My water started turning green!
Jun 16, 2009 | Hayward SAND FILTER, PRO SERIES
Pool need to know how hoses hook to pool
from the skimmer to inlet pump -from outlet pump to in let filter -from out let filter back to pool return
May 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
1,064 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
