Question about Electrolux EW1000i Front Load Washer
Error codes for Electrolux front load washer EWF 1087
E40 is the code showing
Posted by redplanet581 on
Anonymous
  • 27 Answers
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
  • sullivan07 Feb 26, 2011
    mine says E40 error but the door is locking well. What is the pcb
Warren Eather
    New Friend:
Just fixed my E40 error by replacing Door Lock mechanism.
got it from here.
http://shop.onlineappliancespares.com.au/1249675-p-6892.html?cPath=304_5784_5981
Arrived in 3 working days.
Remove 2 screws at top rear of machine and slide top lid off.
Open door and remove 2 screws on latch.
manoeuvre Door Lock mechanism to top of machine. (see photo)
replace part! Put those screws back in. Wash your clothes! 10 minutes.
error codes for Electrolux front load washer EWF 1 - 2_28_2013_11_47_00_pm.jpg
Posted on Feb 28, 2013
Anonymous
    New Friend:
Excelelnt advice - closed door again firmly and held there whilst i reset the wash cycle worked a treat. Thanks!
Posted on Jul 09, 2011
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
2answers
Ewf 1087 error 4h
Hello - Are you certain the error code is E4H? This manufacturer does not have any E4H error code for any washer or other units. They do have E4A and E5A codes however.
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
5helpful
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer
20helpful
6answers
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
14helpful
2answers
Electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Electrolux EW1000i Front Load Washer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
