Question about Fedders Q Chassis A6Q10F2A Air Conditioner
Can't find a manual for air conditioner
Just bought a fedders model a3x05f2a air conditioner but can't seem to find an outlet that carries a manual. What is btu, 5000, 6000, ? serial looks like jm140268 2740 ?what does that mean?
Posted by spider1951 on
Anonymous
    New Friend:
  • 34 Answers
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
How many btu's does the fedders model # A6X05F2A have?
The unit should have a boiler plate behind the front panel indicating btu's and other electrical parameters. Look for it. Or Google the unit
5000 btu..
Jun 01, 2014 | Fedders A3X05F2A Air Conditioner
LOST INSTRUCTION MANUAL-CAN YOU GET ONE ONLINE
Check on their website. Most electrical things do, yes. It's finding the site that's a problem.
Aug 17, 2011 | Fedders A3X05F2A Air Conditioner
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
I have a damaged plug on my Fedders A3X05F2A air conditioner. I cut it off but can't tell which is the white and black wire to attach to replacement plug.
Have you tried to carefully strip the outer insulation off the wire, to expose the 2 or 3 inner wires? If not, doing that will give you the color codes.
May 23, 2011 | Fedders A3X05F2A Air Conditioner
Installing problem
type the name of your device followed by manual in any search engine
Jul 20, 2010 | Fedders A3X05F2A Air Conditioner
Our air conditioner is not cooling as well as it has in the past. We can't find the manual to troubleshoot. What can we do besides clean the filter?
clean the fan blades, and clean the evaporator coils and fins. The entire unit needs periodic cleaning, not just the filter.
Jun 22, 2009 | Fedders A3X05F2A Air Conditioner
Fedders Q Chassis A6Q10F2A Air Conditioner Logo
599 people viewed this question
Top Fedders Heating & Cooling Experts
Ekse
Mike
Harjeet s. bola
Harjeet s. bola
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
