Question about Refrigerators
Why does my refrigerator freeze everything? The refrigerator is about 12 years old and started freezing everything a while ago. I am getting tired of trhrowing out vegetables and everything that can't take the freeze. Suggestions?
Posted by cherspin on
Robert Moller
    Guru:
  • 1,524 Answers
Change the thermostat
Posted on May 21, 2010
My WSN11SS freezer compartment in about every 12 hours it does defrost and everything is defrosted then it starts to freeze again......
control board may be defective. consider replacing it unless the freezer is over 10 years old, if it is that old, consider replacing the entire unit.
Mar 26, 2018 | Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
741 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
