Question about Kenmore Sewing Machines
Have a Sears-Kenmore Sewing machine 158-14000 Had removed the 4 screws that hold the upper gear box on in order to lubricate it. Something popped and now only 1/2 the sewing machine is moving internally. It won't zig-zag.
Posted by macgyverdb on
nurse17trail
    New Friend:
Machine will not sew forward. It will sew backward on zig zag stitch. Could this problem be the reverse switch spring broken?
Posted on Jul 03, 2011
My Singer sewing machine model 500A is slow and I see and smell smoke
This sewing machine doesn't have a belt. The motor is bad or the gears between the motor and the upper horizontal rod is worn. Remove the hand wheel by removing the screw from the outside edge. Then you can turn the brake (in center) and pull the assembly off. Take the gear out from inside by sliding it out. (Remember order) N
Oct 23, 2014 | Sewing Machines
385 kenmore sewing machine
385 just means it's a Janome badged for Sears. The actual model number is the first 4 or 5 digits after the 385 portion.. like 385.1234567890
Machines that don't reverse are often dirty or the lubricants are gummed up (try running the machine in 15 minute bursts, full throttle, with the needle out; sometimes that helps.) Otherwise: https://answers.yahoo.com/question/index?qid=20091124135216AAUyR3H
Mar 23, 2014 | Singer 3116 Simple
How to oil brother PE 770
Brother says it should not be oiled but having 14 of those, I know that it has to be done but a Brother technician will not do that. OILING the machine may cause F05 speed sensor error. See how to solve it under this label.
U need to remove the complete front plastic panel. 3 screws on the top (2 lower the handles, 1 at upper right. Remove 1 screw at the center bottom of the rear panel. Remove both left top/ bottom panels (1 screw each) then the horizontal bottom left panle (2 screws). All the balance is fixed with clips.
First undo the 2 clips under the machine than carefully unclip everywhere. Front panel have 2 wire assembly attached to main board. Regular one is easy to remove. To remove the flat one, send down the upper part of the attchment on the main board.
Don't use reg. thin white sewing machine oil, it evaporate. Use SAE 80 (differentail type) oil or something like taht. Lubrificate all 4 lower shaft supports, rotary hook gears and central pin (from the top, under the bobbin case). Then lubrificate all the upper shaf support and especially all the needle bar mechanism. U need a good light to see upper needle bar support. Lower needle bar support support is the most critical point.
Apr 23, 2012 | Brother PE770 Computerized Sewing Machine
How to oil a kenmore sewing machine 158.19411
Remove bobbin and presser foot, and tip machine on its side onto a towel. Remove bottom plate w/ screw driver. Oil moving parts with Zoom Sewing Machine oil, one drop, and lube up gears that show dryness with Singer lubricant in tube. One drop oil top of needle bar, one drop on oscillating hook in race shuttle. Jimmy
Apr 06, 2012 | Kenmore Sewing Machines
HOW TO TAKE APART 385.19233 SEWING MACHINE
Unplug sewing machine.
Tip machine gently back onto a towel and use a screw driver to remove screws on bottom plate.
If you wish to oil your machine, only oil moving parts with good quality sewing machine oil - no more then one drop. The gears can be greased with Singer lubricant. Of course, never use cooking oil or body oil to oil or grease machine as this can coagulate in the machine and damage it.I hope this helps.
Jimmy
Mar 03, 2012 | Kenmore 19233 Computerized Sewing Machine
How can I fix a drop-in bobbin
  1. Cleaning and oiling the machine
    • 1 Unfasten the top, bottom, side and handwheel covers, using a screwdriver. Set the covers aside.
    • 2 Remove the plate that covers the thread bobbin. If it is screwed in place, use a screwdriver. If it is held by a clip or magnet, use a small flathead screwdriver to pry up the plate.
    • 3 Thoroughly clean inside all the openings, using a vacuum with crevice attachment. Remove any stubborn lint, and use tweezers to take out any thread that is wound around the parts.
    • 4 Clean the teeth on the gears, using the tip of a round toothpick to loosen the grime. Vacuum to remove it.
    • 5 Lubricate all the moving parts. Use white lithium grease on the gears, and sewing machine oil on the other parts.
    • 6 Reassemble the machine and plug it in.
    Tightening or replacing the drive belt
    • 1 Remove the top cover, bottom cover and handwheel cover, using a screwdriver to take out the screws.
    • 2 Inspect the drive belt. If it is slack, use your screwdriver to loosen the screws that hold the motor in place, then follow step 4, below, to increase the belt's tension. If the belt is cracked or broken, get a replacement from your sewing machine supplier.
    • 3 Install the new belt. Loosen the motor-mounting screws, and shift the motor toward the handwheel so you can slip the belt over the parts.
    • 4 Shift the motor away from the handwheel to increase the belt's tension, then tighten the motor-mounting screws and check the tension. The belt should flex no more than 1/2 inch (12 mm). If it is too loose, increase the tension.
    • 5 Reinstall the covers and plug in the machine.
Oct 20, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
How to replace upper thread guide part on Kenmore Sewing Machine 385.16120200 I already have purchased part from Sears.
You will have to remove the upper housing. I can not find a service manual for your model but here is the owners manual that may help you.
Jan 15, 2011 | Kenmore Sewing Machines
I need the screw for my presser foot lever on my Sears Kenmore sewing machine, model 158.17600-pretty sure the part is 31027. If I don't have this part I can't get the presser foot to lower, correct? Or is...
I would go online to Sears parts direct (google it) and order that part. Or, if you have a sewing machine repair shop near you, I bet that they can set you up pretty reasonably inexpensive. Good luck
Nov 10, 2010 | Sewing Machines
Bobbin winder on kenmore model 148 15600 not working
I have the same model machine with the same problem!
The shaft of the bobbin winder 'froze' (apparently from old or incorrect lubrication). When it froze, it's rubber wheel (which they call a 'ring'') that is driven off the back of the main hand wheel (to the left of the winder) developed a flat spot, so it also had to be replaced. (Enter the machine model number at /www.searspartsdirect.com to see how it fits together. Their exploded parts diagrams are excellent.)
Two screws hold the top cover on the machine, and two screws hold the bobbin winder to the underside of the cover. Note that the winder assembly mounts are slotted, so when reassembling, the winder must be adjusted to engage with the drive wheel. (Note its old position.)
You might be able to use a penetrating oil to clean the bearing without dis-assembly of that shaft from the bearing, but that didn't work for me.
I tried to get a whole new bobbin winder (Sears pt # 214458), as well as a new ring (Sears pt # 61662). but Sears no longer stocks that.
I found the ring cheapest at http://www.a1sewingmachine.com, but they no longer had the winder.
I found both parts at http://sewingmachine221sale.bizland.com/store/page21.html, but before the order arrived, I was able to repair the old one, so if the winder does arrive I'll have it as a spare.
I made a fixture to remove the press-fit wheel (that mounts the ring) from the shaft, so I could clean and re-lube the shaft bearing. I used a lathe to drill a 8mm hole > 40 mm into the end of a 1/2 in. aluminum rod, and mounted the rod in a press, and used a 3/16 steel pin to push the shaft out of the wheel. Clamping the rod in a vise and using a pin punch /hammer might also work, but it was very hard to separate them, so that might not work.
When lubricating the shaft/bearing of the winder, be sure to use a good quality sewing machine oil. I've had bad experiences with bearings like this lubed with generic oil (like 3-in-one oils) which gummed things up in a very short time.
Good luck
Paul Higgins
[email protected]
Sep 30, 2010 | Kenmore Sewing Machines
The upper thread spool breaks all the time when I start sewing after four stitches.
Step 1
read the manual completely before u start.
Step 2
Use the handwheel to make the needle rise and fall. Repeat this process with the foot pedal, treadle or knee press. Wind a bobbin and thread your sewing machine. Sew several test seams to assess the problems with your machine. The most common problem is a tight or sticking handwheel and machine movement. Step 3 Unplug your Singer sewing machine and dismantle it. Remove visible screws and take the machine apart as far as you are able. If the motor is mounted on the back of the machine, remove it. Repairing a Singer sewing machine, regardless of the problem, will start by taking apart the machine, cleaning it and oiling it.
Step 4 Use tweezers to remove any loose threads from the bobbin area and threading assemblies. Compressed air may also be used in small amounts; however, you should be wary of pushing lint further into the machine.
Step 5 Use a rag with a lubricant like WD-40 or Liquid Wrench to clean all accessible gears and moving parts. Wipe the lubricant away thoroughly and apply a drop of sewing machine oil on moving parts of the machine. Examine your Singer sewing machine carefully for broken gears or pieces. Check the belt, if visible, for signs of wear.
Step 6 Use an emery cloth to smooth away any burrs or rough spots on the bobbin assembly or feed plate. Often a small burr can cause significant problems with thread breakage.
Step 7 Reassemble you Singer sewing machine, assuming you cannot see any visible broken parts or damage. Try sewing with your machine again. If you have noted problems with the motor or gears, your local Singer repair shop may be able to order parts for you if you want to handle a more involved sewing machine repair on your own.
Step 8
Use a mild solution of water and a basic soap, such as Dr. Bronner's or Ivory dish liquid, and a clean, well-wrung rag to wipe down the outside surfaces of your Singer sewing machine. Dry the sewing machine well. Very old machines may benefit from an application of sewing machine oil to the exterior of the metal sewing machine casing. Rub in well and wipe away the excess.
now try sewing... hope ur problem could have been recovered.
Jan 11, 2010 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
332 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
