Question about Nintendo DS Lite Console
Ds lite screen is fading out to black and just wondering what ohms the ds vr1 and vr2 need to be or if there are any other ways to fix the fading?
Posted by lot0 on
mamidalavigneshbalaji
    New Friend:
My nintendo ds is not coming up screen what I must do
Posted on Oct 13, 2012
Anonymous
    New Friend:
  • 20 Answers
DS lite Vr1 VR2 are same product, they are most easy broke if you try to adjust for LCD screen,hard to find where to sell, just fine the following site have
http://www.logictoyz.com/nintendo-ds/nintendo-ds-lite-spare-parts/nintendo-ds-lite-vr1-vr2-variable-resistor-trimmer-potentiometer-set-2pcs-.html
you need to solder it
Posted on Nov 07, 2010
  • CrossfireSYS Aug 19, 2011
    tried to order from them, after a month of no response, started a paypal claim, for a month, they never responded to paypal. so lost the part, but got my money back
2001 kawasaki drifter 1500 is a vr1 or vr2 ? @
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
2001 Kawasaki Vulcan 1500 Classic Fi Owner Manual
Kawasaki VN 1500 Vulcan Drifter
https://en.wikipedia.org/wiki/Kawasaki_Vulcan_1500_Drifter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 04, 2014 | 2001 kawasaki VN 1500 Vulcan Drifter
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
My VR1 in nintendo ds is damaged...upper screen get hazy while playing...how can I correct it
you must use a little phillips driver and play around very carefully , if it dosent hold in rigth place you will need to replace it , Cheers
May 15, 2010 | Nintendo DS Lite
Black Screen on DS Lite
i guess you will have to buy a new one cause i will not know
Jul 04, 2009 | Nintendo DS Lite Console
Top Screen of DS Lite broken
Replace upper screen and the Upper front bezel.
Or replace the upper screen and the complete DS Lite Housing. You can find them on the well known auction sites. Please be aware that you must know what your are doing. If in doubt, send it to Nintendo or a local Nintendo repair service
John
Sep 28, 2008 | Nintendo DS Lite Console
Ds Lite Touch Screen
The LCD is bad under the touch screen and will need to be replaced.
Aug 13, 2008 | Nintendo DS Lite Console
Hitachi Plasma - green dots
Please read all the info before you start and if you have any question please feel free to message me at [email protected] or just give me a call @ Cell # 1-503-432-9904 Ask for Dave! What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers adjusters.b5e4dcb.jpg You do not want to touch any of the adjusters other then the two that has the location #'s VR1 & VR2 next to them. Please make sure you have located the right adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright thin line over the top of the Blue with yellow center adjusters. This will help you put the adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have adjusted the adjuster. At this point you should have the TV with the back cover off and the TV in the up right position with the stand on the TV. Now you will need to find a friend to watch the screen while you make the adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the adjustment. Start the adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the adjuster back in the factory set position and turn the adjuster VR1 clock wise until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2! WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page. Please feel to message me or give me a call if you have any question regarding the repair of your TV! Thank you! 03.gif Dave All TV Repair Cell # 1-503-432-9904 [email protected]
Aug 05, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Nintendo DS Lite Console Logo
542 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
