Question about Andis Health & Beauty
Andis fade masters
Undecided QuestionShow me another ยป ANDIS FADE MASTERS BLADES WONT MOVE AND LOUD NOISE? I got new fade master andis clippers but the second day of use it started making a really loud annoying sound. I opened it up to see whats wrong but that only made the sound muchhhhh louder. Now the blades dont even move and if i adjust the power from the side the noise can go away if i move the adjuster counterclock wise and clockwise makes the noise come back again but the blades still not moving please help thank you.
Posted by madguzrotts on
5 Related Answers
heidi muehlenberg
  • 62 Answers
SOURCE: loud andis master clipper
If you are keeping the blades oiled correctly and turning the screw per the instructions does not help you will need to send your clipper in for and internal adjustment. You can call Andis customer service at 1-800-558-9441 to find the service station nearest you or you can send the unit directly back to the factory.
Andis CO
1800 Renaissance Blvd
Attn: Repair
Sturtevant, WI 53177
Posted on Apr 23, 2008
Anonymous
  • 61 Answers
SOURCE: how to replace the cord
In order to replace cord,you'll need a sortieing gun,electrical tape, disassemble cord cut sorter-ed end and  resorter.
Posted on Jan 26, 2009
Anonymous
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
KingKutter
  • 8 Answers
SOURCE: loud noise in andis fade master clippers
Try turning the slotted screw on the right hand side of the clipper-while the machine is running.
Posted on Mar 05, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: when i cut hair my andis master clipper seems to
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Posted on Jun 23, 2010
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
Jun 19, 2010 | Andis 01690 Hair Trimmer
Loud noise in andis fade master clippers
Mar 05, 2010 | Health & Beauty
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
Loud andis master clipper
adjust power screw in one quarter turn
Apr 23, 2008 | Andis 01690 Hair Trimmer
Health & Beauty Logo
322 people viewed this question
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Ross Keen
Marvin
Marvin
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
