Question about LG Washing Machines
LG washer Model # WM1814CW problem code UE
LG Front loading washer Model # WM1814CW problem code UE.
Posted by reydeca on
Dan Webster
  • LG Master
  • 8,220 Answers
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2010
sharon
The door is locked so if the laundry is clumped to one side or a nondistributable object is in the tub i cant redistributate the load becasue the door is locked?
Posted on Jan 22, 2015
I have a LG WM1814CW washer that has started giving me the UE error code. No matter what I do it does not solve the problem. I have even run the machine empty and the problem still comes up. It usually...
You may have a problem with the ball sensor. Look in the back of the washer. On the right side as you're looking at the rear, does the frame look slightly dented in?? If so, you will need to pound out the metal. The reason is that the ball sensor is located on the lower right side of the back panel and if it is pushed in enough, the spinning movement from the tub will knock the ball sensor causing the control board to display UE error code. Good luck
Jun 19, 2011 | LG WM1814CW Front Load Washer
I have a LG WM1814CW washing machine that is 4 1/2 years old. I just started getting the UE error code. I get this code even with the machine empty. Obviously a sensor has died on me. Which one?
You have a ball sensor that is located in the rear of machine just behind the rear panel. Check to make sure the ball sensor is properly mounted to the metal frame and the frame is not bent inward as this will make contact with the tub when it is try to spin. Good luck.
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
An UE Error Code is indicative of a “Unbalanced Error”.
This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Thank You
Sep 08, 2010 | LG WM1814CW Front Load Washer
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Washing Machines Logo
693 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
