The bit you're pointing to isn't meant to have any water in it (and to be honest, probably doesn't).
The leak is probably somewhere nearby, with the water then tracking round the outside of the pump before finally dripping off the lowest point.
There are two approaches to finding the leak.
1. Dry the whole pump assembly really thoroughly, then put some cold water into the machine and (with the power disconnected) carefully feel around the pump body to try to identify what bits get damp first.
2. Use the information that the leak subsides when the machine is draining to narrow your search to the pump suction. Have a careful look at the black bellows (at the right hand edge of your photo), examining all the corrugations for splits and tears. Then check the point where the bellows joins the pump body (the round, creamy coloured object with another hose coming out of it in between your arrowed box and the bellows). Use the dry/cold water/feel around trick to help with these examinations.
A.
In all occasions it is important that your observation
is most important and so is vital to the identification /rectification and
solution. If you have noticed that water has leaked then as the drain hose
pump/valve and fittings are located on the underside of the machine it is
important that you look for possible leaks here. In some cases the drain hose
would be clogged at the drain end to outlet of the house and so there will be
back flushing resulting in overflow to the outside. Also the drain pump/valve
can be clogged or the drain hose clamps can be loose on the grip which can all
cause the leak to occur. Removing and cleaning the drain pump/valve, tightening
of the hose is also very important. Also water can leak if there are gaps on
the front door gaskets and must be checked but this will happen only during the
cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing
Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and
removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
is the most problematic fault in a dish washing machine. In all occasions it is
to replace door seal : click on door seal
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.In this case you need to check the free running off the mottor manually, check the voltage on the motor,If absent the controller is a suspecct. check the capacitor of the motor. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
