CHANGE THE FILTER
I NEED TO CHANGE THE FILTER FOR A.O.SMITH WATER HEATERS CAN SOMEBODY HEALP ME PLEASE.
Posted by DAFRI on
Jeff Meyer
  • 423 Answers
Please post back here the model number of your A.O. Smith water heater. Then we can solve the problem.
Posted on May 21, 2010
Hot water heater
You need to change the elements out
Oct 01, 2016 | A.O. Smith GPVH-50 Residential Water...
AO SMITH VOLTEX ERROR CODE ELEMENT ON HEAT PUMP FAULT ON SCREEN
Copy following link
http://waterheatertimer.org/pdf/AO-Smith-heat-pump-service-manual-321547.pdf
Contact AO Smith for qualified technician in area.
Don't buy expensive water heaters.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 09, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
No hot water - the light shows red. It has had problem in the past months but cutting the power off and back on seemed to reboot the computer. This time the light stays red.
Before calling service technician:
Click following link, the click product, then scroll to page bottom to tab that offers technical literature, and download service manual and operation manual.
http://www.hotwater.com/water-heaters/residential/hybrid/
Read the required installation and maintenance protocol to see if air filter has been cleaned regularly, or the condenser coil might be dirty.
Required maintenance can be done by service tech recommended by AO Smith.
Contact AO Smith to find trained person, and next time, do not install expensive water heater since all savings disappear with service issues.
Gene
h
Sep 08, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Air filter on bottom of hot water heater is clogged
Copy following link with general cleaning instructions for each brand:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Reliance/ AO Smith can be cleaned with feather duster and compressed air.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Mar 23, 2013 | Reliance & 30 Gal LP Gas Water Heater
50 ao smith power venter
Get more air to the unit and clean the air intake.
Open following links to see AO Smith air intake, and inspection technique and troubleshoot by type of gas control valve:
http://waterheatertimer.org/images/American-debris-filter-300.jpg
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 27, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
To light the pilot on my OS Smith water heater, I follow the instructions in the label, but nothing happens, no hot water after one hour. Read that there is problems with water heaters, I have some...
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 23, 2011 | Water Heaters
We have a AO Smith water heater Model CYCLONE X1 s/n - 0813A001865 we are having issues with this unit. The unit iwas purchased in 2008. Can you send me information on this water heater. Our plumber bought...
This doesn't sound fun. I would call the AO Smith technical support number and they might be able to help you figure this out. I hope this helps.
Please vote for this answer. Thank you.
Aug 22, 2011 | Smith A.O. SMITH Cyclone XHE Natural Gas...
Please healp
Can u please make a screen shoot and post here???
we will fix ur problem????
Nov 06, 2007 | Acer Aspire 5610-4648 Notebook
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
