Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
I just installed the dishwasher and do not turn on
Posted by evepr29 on
Jeff Meyer
  • 423 Answers
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
Posted on May 21, 2010
I have a dishwasher smeg SDCY 66X1 We need a instelation manual for the dishwasher
An installation manual would have to be ordered from Smeg although the standard manual could include installation information. Try Googling (smeg)(SDCY 66X1)(manual) without parens and see what turns up.
Aug 15, 2018 | Smeg Dishwashers
What is causing error code 3C?
Refer this issue to the installer. Your dishwasher could have been defective before installation or became defective as a result of installation.
Nov 30, 2015 | Dishwashers
Where is reset button on dishwasher
[PDF]Operating Instructions Dishwasher G 4270 G 4275 - Miele
www.mieleusa.com/manuals_pdf/.../Dishwashers/English.../G427x_us.pd...
installation or use of the dishwasher ..... electricity until turned off with the. "o" button. If the dishwasher is not used for a ... All settings can be reset to the factory.
miele dishwasher reset button Questions & Answers - Fixya
Nov 29, 2015 | Miele Dishwashers
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Dishwasher wont empty
If you have a air gap installed on the counter top (it's the chrome r2d2 looking device) pull the top off and you'll notice a pipe draining into a pipe. Get the dishwasher started and then slowly turn the knob on the dishwasher to drain when you hear the motor kick in you should see water draining thru this device if not buy a new dishwasher and have a licensed plumber install it for you.
JV
Dec 30, 2011 | Dishwashers
Water will not come into tub to start washing dishes
Paul,If this dishwasher has just been installed or there has been some plumbing work done in the sink cabinet. Please check the shut off valve for the water going to the dishwasher. it is connected to the hot water pipe in side on the sink cabinet. if the shut off valve is already turned all the way to the right it is in the closed position. This would mean the water is off. turn the valve to the left to turn the water on.This is very common after new counter tops are installed.Please also check water line going to the dishwasher to be sure it is not pinched
Hope this helps
Nov 10, 2011 | Frigidaire Dishwashers
Hello, I recently installed a new faucet in our kitchen, hence turning the water. Not aware that my wife tried to wash dishes in the dishwasher before i turned the water back on, i think she damaged our...
Without a brand and model number, here is my best thoughts on what to check;
1) Was the shut off valve for water going to the dishwasher turned on after new faucet install? Is it turned on now?
2) Is water getting to the dishwasher water inlet control valve?
3) If water is getting to the water inlet control valve, unplug the dishwasher and check the solenoid to see if it is shorted. Unplug the solenoid. Using an ohm meter, check for 500-1000 ohms resistance. If there is no resistance, it is most likely shorted and needs to be replaced.
Sep 05, 2011 | Kenmore Dishwashers
It wont turn on, brand new.
Hmm!! seems a little bit silly but did you ring the installer?.
If it was done yesterday they have a duty to support the installation be it major or minor
And it should be free
Apr 23, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
151 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
