Question about APC (C73351) UPS System
Overload led constantly blinking
I have a apc 2200va and the overload led constantly blinkling when the ups is on. so what could possibly be wrong with it?
Posted by richardso243 on
Nicholas Enyika
  • 506 Answers
The Overload relay may be faulty. Replace the overload relay. Althernatively turn in the UPS to an expert since there is life power in the circuits.
Posted on May 20, 2010
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
Overload problem
If there is an internal fan oil it's pivot or replace it.
If not circuit board is faulty. Time to buy new UPS. I have one like this that cannot be repaired.
Apr 16, 2014 | APC Smart-UPS XL 2200VA 120V...
My APC ups doesn't power on
If your APC UPS is new but was stored unused for awhile, the battery may have discharged completely. You may find a comparatively less expensive and less time consuming solution is replacement.
Feb 22, 2013 | APC Smart-UPS® XL 2200VA (SUA2200RMXLI3U)...
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL [email protected]
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Oct 21, 2009 | APC Back-UPS XS900 (BX900) UPS System
Overload LED lit, constant warning tone, no load on unit. Is there an internal component available to repair this unit?
I have seen this caused by a defective battery. Disconnect the battery and reconnect to AC and see if the overload symptom disappears.
Lou
Sep 11, 2009 | APC Back-UPS XS900 (BX900) UPS System
APC (C73351) UPS System Logo
1,380 people viewed this question
Top APC Computers & Internet Experts
Gruber Power...
Gruber Power...
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
