NorStar CallPilot 100 Logo
Anonymous Posted on May 20, 2010
Need to upload greetings to Callpilot 100. would like to upload some professionally recorded company greetings. Can it be done on this unit?
Anonymous
Level 1:
New Friend:
  • Contributor 105 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
105
Questions
0
Helped
41501
Points
Yes, using CallPilot Manager (the CallPilot browser), you can import a *.vbk file. The CallPilot Player can convert *.wav files to *.vbk files.
Callpilot will not answer calls
Check AA/LINES
i.e. Line 1 is 001 in programming
line 5 to 8 on older systems is 025 to 028
If you recorded Grtg # 1 then go to Table 1 and make Morn etc play #1
Then check AA/lines and make sure AA = Y and Table = 1 and Ring count set to 0 (or 2 if caller id at site).
Reboot system perhaps.
Just got the Samsung Prostar compact IDCS 18D. It was used and I dont have the manual. I tried to record a new greeting which I did, but I can delete the old greeting from the other company which owned it....
When you go into Voice Mail and record you greeting you must delete the old greeting at the same time - the voice prompts will talk you through this. I have uploaded a video concerning Voice Mail admin, failing this please visit www.abbeytelecom.com for written help,
2answers
1helpful
We loose our auto attendant greeting everytime we lose power.
I suggest getting a battery back up or UPS for this system. If it is a 12 volt system, it should be relatively inexpensive to get one installed. Call a security system installer or a trusted electrician to give you an estimate on a battery backup. If you have one, your system will stay active for up to 24 hours during a power failure. Your Callpilot uses volatile memory, which clears when power is not supplied. If you had a battery backup, it would never lose power and your greeting will stay on it.
Thanks for asking.
-Josh
CallPilot 100 Unplugged it and plugged it back
The CallPilot takes between 4 and 15 minutes (depending on software level) to boot up. After that, the lights should come on for each port connected to the telephone system. If not:
1. Check the wiring between the phone system and the CallPilot;
2. Make sure the wiring between the phone & voicemail systems is less than 50 ft. (15 meters);
3. Remove & reinsert he feature cartridge.
If still not working - the unit needs repair.
Callers are not prompted to general mailbox
Under greeting table 1 set your greeting attendant assignment as 100,that should send the caller to mbox 100 if they press 0 or make no selection at all
22helpful
6answers
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Our call pilot seizes a line and won't let us use that particular line. it says extension 254 in use. we use the callpilot in voicemail mode. and the problem is occuring in a lot of our systems.
Are you sure the callpilot is seizing the line? Press "Feature 985" to display the voicemail extension - if it says 254 then you are correct.
Possible scenarios include: Off-Premise Message Notification; Outbound Transfer; Call Recording; etc. Check with users for these conditions.
2answers
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Top NorStar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
