Canon imageRUNNER 2000 Copier Logo
Anonymous Posted on May 20, 2010
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
  • Hannah Schroeder
    Hannah Schroeder Dec 02, 2017
    We must have the same problem because my copier says it's jammed even though there's no paper inside just like yours does. I bought mine only three weeks ago, and already it's having problems printing my dissertation. I don't know what you're going to do, but I'm going to find a copier repair service that can fix it so I can get back to my school work. http://www.ajcopyrepair.com/services
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on May 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
11452
Points
94
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
Testimonial: "Thanks, it WAS the dial on the paper tray."
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
2answers
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Why does it tell me I can't access tray 4
Because there is a problem with tray four so it makes it disappear First open tray four remove the paper that might be stuck behind it.. Then enter service mode utility/counter, touch details on the meter count, then stop 00 stop 01 then select system 1, then select problem unit isolation, then select tray 4 your going to unset follow the screen, then your going to do the same process again this time set, if the draw continues to not show after this procedure get a tech out to look at it, as for tray three maybe the rollers need replacing have the tech look at them to.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
22helpful
2answers
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Keeps telling me to remove back tray as I have a paper jam. No paper jam. Message won't clear and won't let me put in new ink cartridges which it needs....printer is 2 months old....what gives?
You did not post a Make/Model but with many machines they will have a trap door/panel at the rear of the printer. If paper did not pickup from paper tray properly then it will show a jam message that can only be reset by opening the rear door/panel.
I am told there is a paper jam, I have taken the paper out, went through the diagram and still says jam. I unplugged for a bit and still nothing.
This happens a lot in our office. The diagram keeps saying its somewhere but everywhere you look, there's no paper.
My suggestion (since you were printing 2-sided) is to locate the duplex tray. Normally it's very near where the diagram says the jam is, but on the other side of where you look when you first open up the machine.
On most of our Canon copiers, once you slide the middle section out, it's along the bottom side and generally has a flat handle that you push down to get to it. If this is the case, once you open the duplexer, you may have to look underneath the middle part to get the paper out.
Keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
1helpful
2answers
Paper jam
give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
old marine
old marine
ZJ Limited
ZJ Limited
