We had a small electrical storm last night with a power flicker. Computer and equipment shutdown went to startup this morning but tower will not turn on. We have an APC battery backup with surge protector. All of the equipment has powered up but unable to restart tower. I have moved the power cord around to determine if APC recepticle is at fault. That is not the problem. Any suggestions?
Hi! Try to check if there is any power light or any lights on the machine whenever you try to turn it on, also, try to directly connect the power cable directly to the wall outlet.If you have a spare power cable try to use it.If you are getting the same result, try to unplug the power cable at the back of the computer, press and hold the power button for 10 secs and after that plug the power cable back in and then try to press the power button.Check for indicators if the system is getting power for example, check lights, check if the fan is spinning at the back, check if the dvd/cd drive will open or check if the tower is emitting any sound.If still the same and still no light coming from the tower then it might be a issue with either the power supply or the motherboard, you can call your manufacturer and have the machine serviced if its still under warranty.Hope this helps...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
