Question about HP Media Center m7060n PC Desktop
My m7060n Tower turns on but the key board blinks once and stays off; the screen searches for signal without success and then turns off; the fan in the tower turns on and stays on; and the mouse light stays on.the Computer does not go through (power-on-self-test) post/bios for the keyboard to stay on long enough for me to use f10 12 and key "y" to enable its operation. i want to buy a system recovery application to boot up from the cdrom. do you have ideas of the problem and suggestions to rectify the issue?
It sounds like you have a board that is not booting at all. Remove everything from the board except the system RAM and CPU and switch it on. If it boots now, shut it down and then replace each individual item one at a time, booting the machine after each item is refitted/connected until you fit something that prevents the machine from booting. Pay special attention to system RAM sticks by removing them/it and refitting it as bad connections in the RAM socket can also cause a boot failure but removing and refitting the sticks usually cures this issue.
Posted on May 21, 2010
