Loss of suction
A few weeks ago I ran into the same problem, virtually no suction. First I replaced the bad belt (make sure you fit it right or it'll destroy the belt, luckily I bought 2!) and while the vacuum sounded more "alive" it didn't seem to pick up anything any better. The final solution was taking apart the entire intake port section down to the motor and getting the collection tube. It was filled with junk all the way up. I spent over an hour clearing out gunk and animal fur throughout the tubing. Putting it back together was a cinche because the entire vacuum uses one screw type universally. The whole process was pretty intuitive and its clear it's meant to be taken apart for just this purpose.
SOURCE: Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
SOURCE: Loss of suction in my Hoover Windtunnel bagless selfpropelled upright
Did you check the dirt inlet by the brush roll, filters ok, they should be replaced once a year. Belts can look fine, but if they are a few months old, I am sure they have stretched and the brush roll will not turn like it should under load. It is possible that the motor isn't running up to speed, thereby reducing suction.
SOURCE: Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and
the attachments are being used off the hose, but when the handle is
tipped back to begin cleaning carpets the beater head is getting no
suction. As the handle is being tipped back you can hear what sounds
like a flapper valve in the body of the vacuum opening and then all the
suction just goes away.
SOURCE: loss of suction when using
I checked all the pipes and seals. There is a flexible pipe which you can see underneath that connects the front rotating brush assembly to the vacuum system. This pipe can crack and loss of suction occurs when using it upright. The pipe can be repaired temporarily with strong fabric sticky backed tape (e.g. carpet seal tape). A new pipe can be fitted with a few tools.
u can remove the flexi pipe by pressing the inset button,it may be bit stiff if it had not being removed before.may be something is stuck at the bottom,also remove u bend where most of the stuff get stuck. i just posted how i fixed the suction and over heating problem. pl read it. good luck
