RIM BlackBerry Bold 9700 Smartphone Logo
A
Anonymous Posted on May 18, 2010
BlackBerry Bold 9700 Smartphone: i own a 9700.all the sms messages appear in the sa...
I own a 9700.all the sms messages appear in the same contact name.for instance a get a message from alex all others sms will appear on that same window under the same name
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Aug 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
9219
Points
101
That is really how messages appear in the 9700.
2helpful
3answers
Its locked
If it is locked to network,you can unlock it easily using unlock code.Visit the site Unbblock.com
get unlock code at low cost and unlock Blackberry BOLD 9700.
ALL I NEED IS I WANT TO SEE MY SMS INBOX FOLDER IN MY BLACKBERRY SCREEN.. COZ EVERYTIME I RECEIVE A MESSAGES I DONT KNW WHERE TO FIND IT SO THAT I CAN READ MY MESSAGES..
Press the blackberry button, scroll to "Show All", find the SMS Folder, then click the blackberry button again, and select the folders you wish to unhide.
1helpful
How do I send to multiple recipients sms. I have blackberry bold 9700
when composing a message, a dialog box appears where you can enter the recipients. just enter the names/numbers of the people that you're going to group text. after typing the first name, scroll down to the next line then type the name of the second recipient/the number and so on.
1helpful
Can't send or receive sms from my blackberry bold 9700
High there,
You need to determin if the SMS icon is hidden first.
Main menu > BB menu key > Show all.
If this is not the case you need to look into the message folder, found within your email icon and view folders. If SMS is missing then a handset wipe will be required.
Common issue on 9700
Getting error message uncought exception java.NullPointerException when I try to view SMS messages
If you are getting errors on your BlackBerry Bold 9700 Smartphone, and it is acting up, I recommend refreshing its system software / firmware. This ought to make it run like new.
I hope that helps.
My blackerry bold is not showing my sms text messages when using the "separate inboxes" option anymore.
i downloaded crunchsms but now i have two sms programs running one that came with the phone and one that i downloaded how do i turn off the one that came with the phone. i have a blackberry 9700
1helpful
Can't get SMS messages for the passed few days.
Have you tried the SIM in another handset? Have you reset the handset to default (carrier) settings? If outbound SMS does not work even in another handset, it is more than likely an incorrect routing table entry on your providers end. I had a similar issue where I could not be contacted from one certain network after a number port to a different carrier. The old carrier missed the routing table entry and all my calls from the network were being directed to the wrong IP/Destination.
Cannot send sms but can receive same though message center number is correct
You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone. Many quirky behaviors for these devices are fixed every time a new software version is released. The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
1helpful
I bought blackbary 9700 from dubai i have problem
Many quirky behaviors for these devices are fixed every time a new software version is released. You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
Blackberry 9700 sms some get locked up and i have to reset with battery pull out
Replace the system software of your BlackBerry Bold 9700 to correct your locking up issue. The latest BlackBerry Bold 9700 system software is available through here.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
