My super Nintendo gets power (red light turns on) but there is no picture. Yes I have it hooked up correctly and on the right channel. I even switched it out with another snes I have and it worked fine. Reconnected the other one and again no pic - black screen and no sound
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
Can you open up your snes? If you can take off the rf shield and turn the motherboard upside down and then look in the left corner if you see corrosion you need to jump wire whatever it's connecting to.
SOURCE: SNES Sound but no Picture
either the wires could be shot or to an nes the same wires work but sometimes cause errors
SOURCE: My Super Nintendo-- Black screen, white lines, buzzing sound
You just need to clean the game. Wipe the gold strip on the bottom of the game with a q-tip dipped in rubbing alcohol.
SOURCE: Nintendo NES Repair
Hi sounds like your console has a weak connector pin and is lsing contact with your game. I fixed mine buy purchasing a new connector pin from www.gameoz.com.au and it included step by step instructions with photos and a few tips on how to clean NES cartridge games as their is no use in installing a new 72 pin connector if you dont properly clean the NES games because installing dirty games into a new connector pin will result in console blinking flashing again.
SOURCE: reset button on super nintendo
The power button on my N64 is broken so you need a 4.5mm screw driver to open it up and see if you can fix the reset button then.
