Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I have a Craftsman garage door opener 1/3hp chain ...
I have a Craftsman garage door opener 1/3hp chain drive part number 41A5021-3E The garage door doesn't work with the remotes. I replaced the battery in one thinking that was the issue then the next day it didn't work again so I unplugged the battery and plugged it right back in to the remote and it opened the garage door. The following day it did it again so I started using the other remote and that worked once. Now the last 3 days neither one has worked.
Don Maggard
    President:
  • 3,197 Answers
Sounds like your logic board is going bad. The part number you listed is the logic board.
Posted on May 20, 2010
4 Related Answers
Don Maggard
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I cannot reprogram the keypad outside the garage....
Make sure the battery is good and then locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to the keypad and key in a 4 digit code and press enter.
Posted on May 05, 2010
Don Maggard
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I use a genie wireless keypad on a craftsman o...
No each manufacturer uses a different code that is built into the keypad.
Posted on May 18, 2010
Don Maggard
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: liftmaster garage door lock button...
This button toggles off and on by holding in for 3 seconds.
Don Maggard
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: one lift spring is broken...
Replacement of both springs is recommended.
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Can I buy a new remote for 41A435-7
Ebay.
http://www.ebay.com/sch/i.html?_odkw=41A435-7+remote&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=Sears+Craftsman+LiftMaster+Chamberlain+Garage+Door+Opener+Wireless+Keypad+Model+976LM+Security%2B&_sacat=0
Jul 08, 2014 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: i'm reinstalling my garage door opener because the...
Terminal #1 - White wire with red tracer from wall control
Terminal #2 - Three solid white wires. One from wall control and one from each of the door sensors.
Terminal #3 - Two white wires with black tracer from the door sensors.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener model 139.53615sr. can i
You can buy the chain and cable assembly at any good door opener service company. I doubt you will find aftermarket though.
Nov 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
671 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
