The first thing to is try to eliminate the cartridge as a cause of the fault. You can do this by swapping the connections around on the cartridge. If you get the weakness still on the Red cable you know it is that. Solder joints do cause trouble, often the earth is the problem. Try resoldering the joints. Or replace the entire cable as there might be a break.
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
The phono cable's do tend to fail, usually near the phono plug or under the cord clamp.
The best option is to replace the cable - look here :- http://stores.ebay.co.uk/methleykev
this is a broken connection or a bad transistor output , but it will need to be tested to determine the cause or causes
hope you find this helpful
and plz rate my help, and if you need more help just let me know!
