2004 BMW 325XI AWD 2.5L EFI DOHC 6cylFusible links are often identified by the color coding of the
insulation. Refer to the accompanying illustration for wire link size
and color.
Fig. Common fusible link color coding
Circuit Breakers -
Resetting & ReplacementCircuit
breakers are located inside the fuse panel. They are automatically
reset when the problem corrects itself, is repaired, or the circuit
cools down to allow operation again.
Fuses ReplacementUse the
provided plastic fuse puller located in the fuse panel to remove fuses.
The upper lid of the fuse panel has a diagram of the fuse locations and
amperage ratings for each circuit. The fuse is removed by simply
pulling upward on the fuse with the removal tool.
The fuses are easily checked by visual inspection. With the ignition switch
OFF
pull the fuse out of the holder. Check the fuse filament. It should be
continuous and not broken. If the filament is broken, replace the fuse
with one of the same amperage rating.
The fuse and relay box on the E30 and E36 models is
located in the engine compartment. The E36 models also has relay boxes
located under the left side of the dashboard.
The diagram is in section 610 of the Bentley Manual. Some have downloaded it through a link provided here:
http://www.bimmerwerkz.com/forum/3-s...4-a-50762.htmlGood luck.
