Kenmore Elite HE3 Steam 8674 Dryer Logo
A
Anonymous Posted on May 18, 2010
Elite HE3 Steam™ 8674 Dryer: my kenmore elite he3 dryer will lite up, but when...
My kenmore elite he3 dryer will lite up but when I push start it will click and not do anything can you help me?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 30, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033278
Points
35540
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
How do i switch from propane to natural gas on a Kenmore he3 Dryer
You would have to change the gas train out to a natural gas one, the orifice sizes are different.
Kenmore elite dryer he3 dryer taking long time to dry
disconnect vent tube run dryer, as the vent is restricted. Good Luck Tim
Kenmore elite he3 gives me the pf signal and turns off ? what may the issue be?
this is regeristering a power failure,you will need to check the main power supply.there is also a chance that the main control board may be faulty you will need to check all the wiring to the unit.
He3 dryer wont start
those are error codes or warnings if its under warranty call sears for service
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
1helpful
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
7helpful
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
1helpful
We are new to the Kenmore Elite HE3 8674 dryer and it won't run
Our daugther in law came over, and she forcefully shut the door, and the dryer started working. We are going to have the Sears people to come out and make certain that this dryer is not damaged.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
