Question about NetGear WG602 802.11g/b Wireless Access Point
Reset router at school and need to make it secure again.
I reset the router at the school i work at. Now it is no longer ICT systems office (now its just Netgear) and is unsecure. Want it back to secure but can not get to it do so.
Tried the default IP address and followed instructions but no luck!
Any help would be excellent!
Posted by mattanstead on
5 Related Answers
Anonymous
  • 110 Answers
SOURCE: Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Posted on Oct 19, 2007
ggomez
Gustavo Gomez
  • 4 Answers
SOURCE: cant access my netgear router config screen
I have found my own solution to this problem. A cheap Lynksys wireless. I have found that it is fruitless trying to talk to netgear or Apple reps, one never gets to talk to someone really knowledgeable, and it is too frustrating having to step through their scripted questionaire. In addition there are a lot of well-intentioned people that can send you in a wild chase. No worth the waste of time when a $40 or less Lynsys would solve the problem. Good luck to the ones who still have the problem and still want to pursue a solution. Thank you to those who tried to help.
Posted on May 07, 2008
Anonymous
SOURCE: Netgear usb not getting IP Address
I've just had a similar problem with my WG111T connecting to a Tiscali provided Thompson ST585 router.
My problem was that my WG111T was reportedly connecting OK to the router but that then the router would not assign an IP address to the PC.
I figured out the following - download the latest WG111T driver from Netgear (I used 2.1 from http://kbserver.netgear.com/products/WG111T.asp).
Follow the instructions to deinstall your old driver and to re-install the new.
THIS IS THE IMP BIT. When the Netgear instalation process gives you the option to use the Netgear config - it;s marked as (recommended) then DO NOT pick this. Instead pick the std. Win XP config option.
This then meant that I could control the input of the security key myself.
This worked for me!
Why? Well i'm guessing here but I think it's to do with differences in WEP / WPA-KSP.
Anyway hope that helps
Posted on May 18, 2008
Anonymous
  • 65 Answers
SOURCE: netgear wg111v2 wireless usb adapter wont acquire ip address
Not sure if this is where you are looking, but it probably is. click START then CONNECT TO then SHOW ALL CONNECTIONS then right click LOCAL AREA CONNECTION click STATUS then SUPPORT,,,
or CONTROL PANEL then NETWORK CONNECTIONS then right click LOCAL AREA CONNECTIONS then click STATUS then SUPPORT tab
See what you have there for an IP address
Is it the computer you don't have an IP for or the router? In my case my computer IP the 8th or last digit is the next number after what it is for the router. The other numbers are the same
Posted on Nov 27, 2008
Anonymous
SOURCE: Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Posted on Jul 30, 2009
User and password after hard reset
When you do a hard reset it will reset you router. what you need to do is login to your router using the factor seting and reconfigure the router again
Feb 16, 2012 | Linksys Wireless-G WRT54G Router
My belkin surf suffers from constant disconnects, i've loaded the latest firmware and made sure all my settings are as what my isp has instructed me, Iv'e also borrowed other routers and found they...
You are correct in hearing that Belkin products are often unreliable. I suggest going with a linksys wrt54g router. Very reliable and a great price as well
Jun 06, 2011 | Belkin Wireless Surf Router (F7D2301)
I forgot my user name and password what can I do.
Clear the settings and start again. To do so, press the reset button for longer than 30 seconds, then ....
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
My computer is no longer picking up my router. Its asking me for a security code that I dont have.
try to use admin admin or user user. if doesn't work reset your router and configure it again using
your router manual.
Jan 13, 2011 | Dynex Enhanced-G Wireless Broadband Router
My router no longer seems to work. Is there a way I can reset it and see if it will work again.
Try doing a power drain: Disconnect power cable from the router and also the network cables and then connect all the cables back after 2 minutes.
Reset: There is a reset switch available in the pannel along side to the network cable and power cable, use a pointed object like a small pin / screw driver to pre and hold it for 5 - 10 seconds to reset the router
Caution: Reseting the router with the reset switch will remove all settings from the router including the security settings and will retrun the settings to factory settings and we have to setup the router once again.
Jan 03, 2011 | D-Link DI 514 Wireless Router (DI-514)
I got a new computer....cant remember my password to linksy and ofcourse have had linksy so long i no longer own the disk...help
These are instruction to Reset and Restore the “Router Password.”
The first thing you want to do is to “Reset” the Router’s configurations to factory defaults settings, hold the reset button on the router for 30 seconds. jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/GlobalPhoto/Articles/2188502/adminpwd_Full.jpg'); }); Once your router resets, you will need to Login and reconfigure it again.
To reconfigure your “Router” connect the Computer to one of the Ethernet Ports. Next, type in your Web Browser, and go to URL http://192.168.1.1/. “You will be asks you to enter a “Username and Password to login to your router,” or use the router’s (“Default Password”) which is “admin.
“You should be able to reconfigure the “Router.” Next, go to the Management (Tab) to change the Administrator’s password.
Next, you will need setup the Security for the Router, by selecting to (“Enable”) the “Security Codes,” example: WEP “Rating the solution, if it helped? is appreciated, thanks”
Feb 23, 2010 | Linksys Wireless-G WRT54G Router
I cant remember my login or password. how do i reset these?
on the back there should be a little hole with reset above it, Get a paper clip or pin and push it in the hole and you will feel a button click in.
Kept it hold down for about 10 seconds and you should see the lights start flashing and your router is then reset. If it doesnt reset the first time, try holding the reset button in a bit longer.
Good Luck :D
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter, home networking. I am on AOl using Thomson speedtouch, I am trying to link up 2 pc's and one laptop to access the net. Main Pc is Vista - with wireless...
try to reset the wireless router to factory default.( with out encryption). connected the Xp first. then the other two.
try to use simple encryption (8 characters).
Oct 12, 2008 | Belkin Computers & Internet
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
Aug 25, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Password
this is easy just look at the back of your router and there will be a small hole, just push a pin into it for longer then 6 Sec's and Bingo your router will be reset back to factory settings again (NO WEP etc), hope this helps you, and don't forget to reset your WEP and MAC up again will you. dont forget to rate me if u like my solution
Nov 13, 2007 | Westell Wirespeed VersaLink...
NetGear WG602 802.11g/b Wireless Access Point Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
