Question about Fisher and Paykel Fisher & Paykel Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Smartdrive 058 leaking by the pump
Anonymous
    New Friend:
    Problem Solver:
  • 10 Answers
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
Posted on Jul 11, 2010
How to clean pump from smartdrive 501?
there is no cleaning as such,but if your havig drainage problems then remove pump check for anythining that might jam it and lookat the electrical windings for any discoloutation if there is replace pump
Jul 06, 2014 | Fisher and Paykel Fisher & Paykel Washer
Smartdrive 601 leaking
If the tap is leaking replace the washer in hose end. It's a common garden hose washer. If you mean there is water in the tub your inlet water valve needs likely needs replaced.
Jan 11, 2013 | Fisher and Paykel Fisher & Paykel Washer
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
My smartdrive 058 the water temperature lights up on hot, when I set to warm cold it beeps and does nothing until I press it. Why?
this is what we call a user fault : you may also hear a series of beeps as well usaly idicates hot water is not detected this may occur when warm or hot is selected solution make sure hot water is avalible to machine
Jan 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
278 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
