Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar5316 how to change destination setting Europe to Asia
Posted by bonnie_3023 on
amir hamza
  • Sharp Expert
  • 318 Answers
Semuletion cod 26-6
4 for asia
Posted on May 20, 2010
I have classic model KM-2030; need code to change paper size from 8-1/2 X 11 to A4. Thank you!
Setting the destination Description
Switches the operations and screens of the machine according to the destination.
Purpose
To be executed after replacing the backup RAM on the main PCB or initializing the backup RAM by running
maintenance item U020, in order to return the setting to the value before replacement or initialization.
Enter Maintenance Mode
Enter "10871087" from keypad, You should now be in maintenance mode.
Enter "252"press "Start / Print" key.
Select your destination from list on the display.
Press "Start / Print" key.
Enter 001 "Start / Print" key to exit to normal display.
Method
Press the start key. The screen for selecting an item is displayed.
Setting
1. Select the destination using the cursor up/down keys. The selected item is displayed in reverse.
Display Description
JAPAN METRIC Metric (Japan) specifications
INCH Inch (North America) specifications
EUROPE METRIC Metric (Europe) specifications
ASIA PACIFIC Metric (Asia Pacific) specifications
2. Press the start key. The setting is set, and the machine automatically returns to the same status as when
the power is turned on.
Completion
To exit this maintenance item without changing the current count, press the stop/clear key. The screen for
selecting a maintenance item No. is displayed.
Feb 09, 2011 | Kyocera Mita RADF-11 REVERSING...
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to change destination settings?
go to cod condition(# interrupt c interrupt) LCD turns off.enter 26 press copy enter 6 press copy enter 4
then copy.
May 20, 2010 | Sharp AR-5316 Advanced Digital Imager...
What does RC 1 mean
RC means REGION CODE - Depending on the numbering, it means that your DVD will only play in countries designated by the code.
Example
RC 1 means Region Code 1...... This disc will play in dvd players in Canada, United States, U.S Territories , Bermuda.
RC 2 = Western Europe, incl. United Kingdom, and Central Europe; Western Asia; including Iran, Israel and Turkey, Egypt; Japan, South Africa, Swaziland, Lesotho; French overseas territories
RC 3 = Southeast Asia; South Korea; Taiwan; Hong Kong; Macau
RC 4 = Mexico, Central and South America; Caribbean; Australia; New Zealand; Oceania;
RC 5 = Ukraine, Belarus, Russia, Continent of Africa, excluding Egypt, South Africa, Swaziland, and Lesotho; Central and South Asia, Mongolia, North Korea.
RC 6 = People's Republic of China, Hong Kong
RC 7 = Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia)
RC 8 = International venues such as aircraft, cruise ships, etc.[1]
RC ALL means all 8 flags are set and can play on ANY player
0 or no region means no flag is set can be played anywhere or flags 1-6.
I hope this helps.
Aug 24, 2009 | Sharp BDHP20U Blu-Ray Player
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
How can i scan an image to computer with sharp ar5316e
The Sharp product description page lists this device as a printer/copier. It's scan function will only produce local copies on itself and it will not scan to another device or computer.
May 27, 2009 | Sharp Computers & Internet
Sharp AR-5316 Advanced Digital Imager Copier Logo
77 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
