Linksys WRT120N Router Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't have the instructions to my wireless router and i know nothing about them can you help
inoastar
Level 2:
Guru:
  • Expert 78 Answers
  • Posted on May 20, 2010
inoastar
Expert
Level 2:
Guru:
Answers
78
Questions
0
Helped
13000
Points
242
Click Here!!
And go to 'downloads', then select your version and a downloadable version will be available!!
hope this helps!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Instruction manual toshiba
I did a factory restore on my Toshiba because after I did a system restore to an earlier date it still was not working like before nor could it pick up any wireless signal. But I could and still can connect through ethernet cord. How do I get my laptop to pick up any wireless signal?
Side note: I have unplugged my modem and router for several minutes. Maybe like 15 min or so. Also turned off my laptop then plugged in modem, then router then turned on laptop....nothing still.
I have tried a few other things suggested on here but still nothing.
*I remember seeing on a screen that wireless was not enabled* I did try the "FN+F8" nothing.
I share a supported links, visit and follow instructions.
Troubleshoot WIFI and Linksys Router Support
Thanks,
1helpful
2answers
Wireless light flashes & can't connect
This post is dedicated to describing the process of fixing an orange light on a Belkin router. But, first, it's important to know about the reason for the orange light. The orange light on the brilliantly-designed Belkin router provides an indication that either the particular connection had not been developed or the router is not capable of detecting the Internet. It might be due to the defected router, unplugged modem, and so forth.
Don't know how to lock my linksys router
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
How to reset epson wp-4530
Try the following solutions
Important: Make sure you know your network s security settings before you set up your product on your wireless network Epson will not be able to provide this information for you If you don t know this information you ll need to contact the manufacturer of your router or the person who set up your network If you know your security settings continue with these steps Reset the product s network settings Turn your router off and back on Warning: If your router is connected to other devices you may need to re establish the connection for the other devices on the network Set up the product for a wireless connection Close all applications including any screen savers, virus protectors, and firewall software before you install the software Uninstall the printer software then reinstall the printer software.If the steps above do not help, check the additional troubleshooting tips below then try steps 1 through 4 again If your wireless router or access point is set to not broadcast its Network name SSID you ll need to enter the SSID manually in the printer s setup software If your wireless router or access point has wireless security enabled, you'll also need to know what kind of security it is using Epson will not be able to provide this information to you If you don't know this information you'll need to contact the manufacturer of your router or the person who set up your network Make sure the product is within range of the wireless router or wireless access point Avoid placing the printer near a microwave oven, 2.4 GHz cordless phone, or large metal objects such as a filing cabinet Check to see if access restrictions, such as MAC address filtering, are set on the router or access point. If access restrictions are set, add your product's MAC address to your router's address list. If your unsure on how to do this, contact the manufacturer of your router for instructions To obtain your product s MAC address, print a network status sheet Disable any settings such as AP Isolation Client Isolation, or Privacy Separator on your wireless router or access point that would prevent wireless devices from communicating with each other
I don't have an instructions on how to set this thing up. I know nothing. Please help...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
I can't seem to connect to my wireless router, \r\nI don't know what the problem could be really, I went through the setup and it should be working fine. Any ideas on how to fix this?
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card in yourcomputer/laptop.
If these settings do not suit you, then go to link and follow my instructions. http://www.fixya.com/support/r10267861-network_security_key
I've plugged the modem into the router and the four lights on the left of the router are on, the middle two blinking; however, despite being able to detect the router wirelessly I am not able to gain...
One thing to try is to hard reset the modem and the router. This will work on an unprotected router that won't connect most of the time.
This link is to the data sheet d-link gives for this router. ftp://ftp10.dlink.com/pdfs/products/DIR-655/DIR-655_ds.pdf
This one is to the software and instillation guides they provide. Select your country from the three. Then there is a link to a FAQ below the two download links that will help you find which of the two that you need.
http://www.dlink.com/products/default.aspx?pid=DIR-825&tab=3
No any led on when put the power in wrt51ab
Check the power supply of your wireless router if it is OK if you know how to used tester check it. If it is OK then checked the software driver of the router if it is properly installed if not re installed it again,make sure to follow the instruction of the manual of router properly.Checked also the settings of other computer you want to link in the wireless router if it is in right settings of wireless connection.
Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up, i really appreciate what grade you have been given to me. Thanks a lot and God Bless.
Hello i have a linksys wireless g 2.4 ghz with speed booster router. the disk got severly scratched so i don t know how to set up a password on my system can you help
Here is a direct website to show you how to setup your router, follow the on screen instructions. Good Luck.
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html (Copy and paste this address into address bar)
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
