Question about Husqvarna Partner Gas Powered Cut Off Saw K960 16"
Oil ratio partner k750 - Husqvarna Partner Gas Powered Cut Off Saw K960 16"
Posted by jag1369 on
rlev_7
    New Friend:
  • 47 Answers
40ml to 1 litre of fuel 150ml to to 1 gallon
Posted on Sep 09, 2010
Replace oil pump in partner 352 chainsaw
The oil pump on this saw is located in the oil tank. Access it by removing the bar and chain, then the metal cover over the oil pump. You will see the oil pump and oil line.
Jul 06, 2014 | Husqvarna Partner K650, K700, K750, K950,...
Repair manual partner k750
http://speedy.sh/A7tjW/K750.pdf This should give you the shop manual
Feb 08, 2013 | Husqvarna Partner K650, K700, K750, K950,...
What is the oil to fuel ratio for the quick cut saw k750
generally 50:1 fuel to oil mix is recommended.
Apr 30, 2012 | Husqvarna Garden
Oil to petrol ratio?Thanks Partner B300BX strimmer
If you are using stihl oil then the mix is 50:1
Jul 31, 2010 | Husqvarna Garden
Was given partner 1612 chainsaw and need to know gas/oil ratio please. thanks
50:1 2.6oz mix per gallon or 100:1 about 5 oz per gallon
May 12, 2009 | Garden
Have '70's Partner R420 chainsaw. What's the
The Oil:Gas ration for a Partner 420 saw is 25:1 if using standard, quality two-stroke air cooled oil. The service manual says 40:1 can be used if you are using Baird/Poulan branded 2-stroke oil designed to be run at 40:1.
Please rate this solution on FixYa!
Thanks
Mar 30, 2009 | Garden
Husqvarna Partner Gas Powered Cut Off Saw K960 16" Logo
882 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rlev_7
Level 1 Expert
robert
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
