Scope was installed on air rifle with a bent barrel and tried to Zero in rifle; but gave up and reinstalling on a air pistol. Now I am no where on paper and do not have a bore sighter and cannot look through barrel, because of configuration. So thinking it is better to reset. On an optical scope, counting the clicks from stop to stop and half the amount is a reset. But is it the same for a red dot; do not want to break it...
Yes it is the same, it has the same barrel inside as a cross hair only you have a red dot. So just like you said, count the clicks and take it half way. You could do it with a vice, put a target up at 20 or 25 yards, depending on the pistol, lock it in a vice, shoot the gun a few times, and then put the cross hairs, dot, on the group, then you can fine tune from there. Check it out. And the bent barrel rifle, I had to stand on a barrel once to straighten it, actually I was jumping up and down on it, but I got it straight.
