Question about HP Compaq dx2450 Microtower PC Desktop
Driver PCI Device nVIDIA nForce 6100-430 (MCP61P)
I can't download driver PCI Device nVIDIA nForce 6100-430 (MCP61P) - LAN Controller
Posted by gaejad on
Anonymous
    New Friend:
  • 3 Answers
I can give you the driver if you give me the exact model of your vidcard... right click the desktop background then click properties, then click settings then look below the picture monitor and look for the Display...
Posted on May 20, 2010
I'm trying to locate the drivers for nvidia Nforce 10/100 lan drivers for an hp pavilion dv9000
Hello
There is a driver disc with this lan card. If you haven't got it when you buy it, it will be very difficult to install it from the net. Anyway, try to download it from the following links. Wich a CD, it will take about 30 to 40 minutes to install the sofftware fully. The disc will install both LAN card driver and Nvedia driver together.
www.nvidia.com/object/nforce_udp_winxp64_6.25.html - United States
www.pcpitstop.com/drivers/manufacturer/nvidia.html
http://www.dataentryjobs.us/67948.html
www.liutilities.com/device-driver/nvidia-nforce-10-100-mbps-ethernet/
Feb 03, 2012 | Computers & Internet
Hi! i hope you can help me about my internet connection i lost my drivers for msi board ms-7309 ver. 1 i only need is for network connection for the internet
Originally Posted by Realtek.com
Q9: Why don't I find RTL8201x driver on the website?
A9:
RTL8201, RTL8201BL, RTL8201CL, RTL8201CP, RTL8201N and RTL8211B(L) are all PHYceiver. That is a driverless hardware device. Software driver are relative to Network controller ( MAC ) which is integrated into chipset in such case mostly. Please contact *********** board maker or chipset manufacturer to obtain proper driver support.
Your motherboard uses the NVIDIA ® GeForce 6100 nForce 410 (MCP61P) Chipset - its set of drivers can be obtained from the official site
http://www.nvidia.com/object/nforce_nf4_430_410_winxp32_8.26.html
Jun 29, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Need raid contoller drivers for Asus P4XP-X
http://majorgeeks.com/DriverMax_d5260.html Win7/Vista/XP . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
Just one single computer restart will be required after all drivers are reinstalled!
DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/nvidia-raid-driver-zip/3000-18492_4-158932.html This package supports the following driver models: NVIDIA NForce(tm) ATA RAID Class Device
  • NVIDIA NForce(tm) ATA RAID Class Controller
  • NVIDIA nForce2 ATA Controller (v2.6)
  • NVIDIA nForce3 Parallel ATA Controller (v2.6)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.6)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.6)
  • NVIDIA MCP2S Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Serial ATA Controller (v2.6)
  • NVIDIA nForce 2 ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.5)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.5)
  • NVIDIA MCP2S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Serial ATA Controller (v2.5)
Apr 11, 2011 | ASUS P4V8X-X Motherboard
Nvidia nforce serial ata controller ... nvidia nforce pci system management..nvidia pci standard pci to pci bridge..nvidia parallel ata controller..texas installation ohci compliance iee... hid compliant...
If you are looking for a motherboard chipset driver first you have to know the name of your motherboard for example like this is one:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=857&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0
This site contains an example of a Ecs Motherbonard that having a nvidia chipset and also containing different device drivers.
But if you are looking for a graphic card controller from nvidia try to visit this page:
http://www.nvidia.com/Download/index.aspx?lang=en-us
In this site you have to identify the Product of Type of your D
Nov 03, 2009 | Computers & Internet
Need windows XP drivers for eMachines t3616
google: nvidia nforce network management. This will take you to
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
You can then download the driver for you network adaptor which will then get you into the internet where all things are possible!
Jan 28, 2009 | E-Machines eMachines Desktop PC
Epox Ep-af550g mobo
If AHCI is not enabled by the motherboard and chipset, SATA controllers typically operate in "IDE emulation" mode which does not allow features of devices to be accessed if the ATA/IDE standard does not support them. Windows device drivers that are labeled as SATA are usually running in IDE emulation mode unless they explicitly state that they are AHCI. While the drivers included with Windows XP do not support AHCI, AHCI has been implemented by proprietary device drivers.[1] Windows Vista[2] and Linux with kernel version 2.6.19 onward[3] have native support for AHCI.
Jan 15, 2009 | Computers & Internet
Unknown device
I beleive that you had downgraded and installed a retail version of XP by erasing the preinstalled version of Vista in your Notebook.
However, all the drivers required for your Notebook may not be available with HP if your Notebook is preinstalled with Windows Vista.
I recommend you to try downloading and installing the drivers for HP Quick Launch Buttons from the link below for the first Unknown device in the Device Manager :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Save the file on to the Desktop or My Documents folder and double click once the download is completed to install the drivers.
For the Ethernet Controller, I recommend you to download the LAN Card Drivers from the link below :
ftp://210.51.181.211/cn/nic/INSTALL_VISTA_6208_0922.zip
Coming to IEEE 1394 controller, you need to download and install the Chipset Drivers which are available through the link below :
http://us.download.nvidia.com/Windows/nForce/15.24/15.24_nforce_winxp32_international_whql.exe
Make sure that you download and save the files in the Notebook and double click them once the download is completed and restart the Notebook after installing each of the drivers provided above.
Hope this helps...
Oct 03, 2008 | HP Pavilion dv9720us Notebook
Cannot Complete the Network Setup..
do you have your LAN adapter turned on in your BIOS - if you do not then that is your problem. also are you using XP or Vista. You can't load the vista driver for XP. Let me know these things and i can help you.
Sep 20, 2007 | ASUS M2N-MX Motherboard
HP Compaq dx2450 Microtower  PC Desktop Logo
2,103 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
