Question about Olympus Camedia C-720 Ultra Zoom Digital Camera
Have a C-720 that has worked fairly well but has developed some recent problems. First, when you turn the camera on, with fresh batteries, sometimes the camera will not turn on. I was told by one person to make sure that I press the button firmly on the back. Sometimes this works, sometimes not. Another recent problem is that the camera is working fine, then when I move the zoom/wide angle lever, the camera freezes, the screen goes blank, and it shuts off. Sometime just taking a picture causes the same issue. One thing that has worked in the past is to open the battery case, switch all of the batteries around, close it back up, and restart the camera. As crazy as that sounds, it has worked, especially ont he freezing issue. Now however, it does not. Help! The battery indicator shows full charge and there is plenty of space on the Smart Media card.
    Brigadier General:
  • 11,967 Answers
This could be a lens problem. Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 19, 2010
I have a samsung plasma display have problem with remote tv works fine just installed new batteries channel up down fine cant turn volume up or down and few other misc buttons work some do not
Try another set of FRESH Duracell batteries. If you are still having problems, wipe the buttons with a fairly damp cloth. Sometimes they get sticky. After that, spray the buttons with WD40 and wipe off immediately. If that doesn't work, ebay has lots of used and new remotes.
Oct 28, 2015 | Samsung Televison & Video
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Camera won't turn on
Your problem is likely battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Polaroid I533P Digital Camera
Fujifilm Finepix a825 Digital Camera Battery Life issue
2 long shots as I don't know anything about the a825
Some cameras have a setting in their menu that allows you to choose between alkaline or NiMh (rechargable). If the setting is wrongly set to alkaline when using rechargable it is unlikely to recognise that the batteries are charged and would report low battery. Check your manual to see if their is a select battery setting and check whether it is set correctly.
Occasionally errors on digital cameras can be corrected by removing the memory card and batteries, leaving for 2-3 days and then putting back in the batteries, turning on, turning off, putting the memory card back in and turning back on.
Feb 09, 2009 | Fuji FinePix Digital Camera
Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Jan 30, 2009 | Kodak EasyShare Z760 Digital Camera
Hp photosmart 720
My Photosmart 720 has also just stopped working. It simply won't turn on, with battery or mains power. So I took it to pieces. Inside is a thumbnail battery, labelled "5.5v 0.33f" which tests out at 3.0v DC. I surmise that the purpose of this battery is to remember the settings when the main batteries run out - but it could conceivably have some other purpose, like helping it to boot. Whatever the reason, it has clearly run down and I would guess that the other people on this list have hit exactly the same problem.
If I'm right, and the camera depends upon this very-hard-to-access battery, it is shocking that HP could get away with selling a camera designed like this. It implies that the camera was cynically designed with the expectation that it would be thrown away after (I would guess) five years. How's that for built-in obsolescence ? It *may* be possible to remove and replace this battery without damaging the camera, but there certainly isn't a manual that tells you how... is there ?
Jul 19, 2008 | HP Photosmart 720 Digital Camera
Freezes when taking/trying to take photos- help
When trouble shooting a digital camera, you only have two options: Battery and Memory Card. If you are using rechargeable batteries, it is possible that one battery is bad. It is also possible that the charger is bad. So, buy 4 Alkaline AA batteries and try them. This will either confirm that your present batteries and/or charger is defective. Or it will confirm that you don't have a battery problem The only way to know, it to try it. ....... The same applies for the memory card. Try another memory card and see if that helps. .....
Sep 06, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Olympus Camedia C-720 Ultra Zoom Digital Camera Logo
104 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
