Question about Honda Landa PG 3500 PSI Pressure Washer
I have a landa hmp-4-3500 heated pressure washer and i am problems with the water heater. where can i find a trouble shooting guide for this machine
Posted by jrsspray on
Aron Kerr
    Scholar:
  • 45 Answers
Landa does not have a model HMP so I am not sure which machine you have. If you can provide a full model and serial off of the model tag on the machine I can provide you with a digital copy of the manual you are looking for.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Posted on Feb 14, 2011
  • Adam Baughman Mar 01, 2012
    Aron, I am looking for an owner's manual for my Landa PWer as well. I just purchased a PG4-35324S rental. The serial number is P1105-11942. Please message me back or email me.
    Thanks,
    Adam Baughman
    [email protected]
  • Aron Kerr
    Aron Kerr Mar 02, 2012
    Adam, I sent you an email this morning that has the manual you requested attached. If you have any questions please feel free to contact me using the information below.
    Sincerely,
    Aron Kerr
    Landa Northwest
    www.landanw.com
    800.247.8103
    503.255.6508
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
What do I do when error code F:08 appears on Front loader Whirlpool WFS1073DD washing machine
The F08 error indicates that the heater isn't coming on. The problem could be the wiring, the heater relay, the element or the pressure switch. Check your error first though. An F0B error is a load out of balance issue.
If the error happens only at the spin cycle, check the load distribution. If it happens when the washer is filling, you'll need a multi-meter and the trouble-shooting guide that is tucked into the washer in the control panel housing. A burnt wire may be visible on a visual inspection. Use the guide to check the resistance and current flow results to narrow down the cause from the other possibilities.
I hope this helps.
Nov 11, 2014 | Washing Machines
Need wiring diagram for the burner on. a Landa 5-3500 pressure washer
If you can provide the full model and serial from the model tag on the machine I would be happy to send you a wiring diagram. The model tag is normally located on either the frame of the equipment or on the side of the electrical panel. Depending you your model it should look something like the following.
Model: PGHW5-35324ESerial: P0108-890345
We are the original Landa factory in Portland, Oregon and have digital copies of user manuals, breakdowns and wiring diagrams for every machine that Landa has ever produced. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, [email protected]
Apr 16, 2012 | Garden
How do u take coils out of burner from a landa pressure washer
If you are talking about the water coil for the burner it will depend on the specific model of the washer, however it is a similar procedure amongst all our washers. For horizontal coil machines you first need to remove the bolts securing the top wrap, then fold back the fiberglass insulation to reveal the coil. Next un-hook all plumbing from the inlet and outlet of the coil. Now if you look at the top of the coil you will see a threaded hole in the center. You can secure a chain to this with a 3/8 bolt and washer in order to help you lift it out.
For a vertical coil you will need to remove top cover from the burner wrap. Next un-hook all plumbing from the inlet and outlet. Now secure a chain to the top of the coil and lift it slowly from the wrap.
If you have any other questions please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Feb 01, 2011 | Heating & Cooling
My hot water is not working i have power to relay that is new but it will not send power to my on off switch
I am a little confused by your question because a PG is a cold water pressure washer. In most mobile hot water machines there will not be a relay. My best guess is that you are talking about a GFCI that is not sending voltage to the On/Off/Burner cam switch. To check this you will need to verify that voltage is actually passing through the GFI. If you can clarify with a model and serial for your machine, I will be able to give you better trouble shooting instructions.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Dec 31, 2010 | Honda Landa PG 3500 PSI Pressure Washer
When chemical injector is attached, it works fine. When I put one of the power tips on, I do not get any pressure.
When using the chemical injector your machine is only having to operate under low pressure. This means that your pump only has to transfer water and does not have to compress it. When you insert a pressure nozzle you cause the pump to have resistance and therefore it has to compress the water to make pressure. If you pump seals or valves are worn the pump cannot build this pressure. You need to either rebuild your pump yourself or have it looked at by a service center. If you have any other questions or need parts or service please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Sep 23, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have an older Landa Pressure Washer. The burner is not working. Once I get the machine running and water flowing to the pressure washer, with the wand pressed, I flip the burner on switch....and...
Check for 12V at the igniter connector with the unit running. If you have 12V and no igniter it may be stuck or bad. Thrun the unit off and read continuity across the DISCONNECTED igniter plug / terminals to the igniter. No resistance = open igniter.
If all of the above checks out your going to have to look at the fuel pressure switch to see if it closes and passes 12V to the igniter.
Before you give up... Check the fuse.
Landa's website is www.landa.com
You will have to select a local dealer for parts.
Thanks for using FixYa!
Kelly
Mar 10, 2010 | Garden
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Landa pressure washer manuals
send them an email at [email protected] or contact them directly at 800-526-3248 for more info specific to your model which was not listed above. hope this helps you
Aug 09, 2009 | Heavy Duty Garden
INGLIS WASHING MACHINE - WATER STOP
Either call the store where you purchased the machine or refer to your users manual, should have a trouble shooting guide in the back of the manual.
Jan 05, 2009 | Zanussi FS1455W Front Load Washer
Honda Landa PG  3500 PSI Pressure Washer Logo
735 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
