Question about SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox plasma television will not turn on, makes
I try to turn on the television and I don't get picture or audio. The television makes a clicking sound. I removed the back of the television and the clicking sound appears to be coming from a circuit board in the bottom middle of the television. There is a marking AK near the spot where the clicking sound is coming from and a small green light blinking when it clicks.
Posted by larrymattern on
electech_fl
    New Friend:
  • 68 Answers
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
Posted on May 19, 2010
No speaker audio Magnavox plasma TV
Re check all connections on the boards that you worked on. Make sure they are tight.
Jun 18, 2012 | Televison & Video
Sound but no picture
it sounds like the cable/satellite connections are inpoperly connected
Dec 12, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
42" magnavox plasma tv lost
The power supply feed deferent voltages to the TV and the Problem is the electrolytic caps need change out on the power supply module, or you can go to www.partstor.com and get a new one.
Aug 30, 2011 | Televison & Video
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
I bought a Magnavox plasma
Hi there! Sounds like the panel is in protection. The Y and Z-Sustain and/or Control board may be at fault. If there are fuses, check these first and replace. If not successful the boards may have to be replaced. Also check the Voltages on the Power supply are correct to manufacturers specs. If not familiar with any of this please refer to a repairer. Bset Wishes and Good Luck, JUS004
Aug 22, 2009 | Televison & Video
There is no picture but have audio
Your mainboard is damaged and need to be replaced. in order to get a new one you will need a product code and model number, both located in the back of th TV next to serial number.
Jun 03, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
50" Plasma turns off and back on without picture; audio stays on
Yes, you are correct. there are a few component issues on the power circuit board that will need to be replaced. the mani component will be the capacitors and transistors.if not repaired soon, this unit will completely stop working.
Mar 11, 2009 | Mitsubishi PD-5030 50 in. HDTV Plasma...
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Jan 27, 2009 | Televison & Video
Magnavox dvix player to ilo 42
what are the modelnumbers on your divx player and your tv? if you are using svideo inputs do you have your audio cables hooked up? have you checked the volume on the player to make sure it is not muted?
once you supply more info i can help you further, until then, check your cables and audio settings on your divx player. and make sure all connections are in the right place
hope this helps
trin
Nov 16, 2007 | Televison & Video
SNK Magnavox 42MF231D 42 in. Plasma TV Logo
931 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
