I have an Maxtor External Onetouch 4 and my computer will not recognize it. It is plugged in correctly, the light is on and it acts as if its running. But my computer won't recognize it. What should I do
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press
windows key +R key so you can see run then type in run "devmgmt.msc"
then press ok so you can see device manager uninstall all usb drivers
then it automatic install usb drivers.
then check.
Also you need
to change registry for that type in run "regedit" then press ok then
you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If
your harddrive still not recognized then you need to repair your
harddrive.Try your harddrive in different computer if it is not
recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
have you tried more than one USB port?
