Is is possible for a homeowner to replace the gasket?
Yes it is and its typically quite easy to do.
First you will need to determine what type of gasket is in the unit. Typically its just a push in style gasket that is held in place by a dart style backing that holds it into place.
A tip to use is to soak the new gasket in screaming hot water for about 5 minutes before installation. The install it right away. The hot water will make the gasket easier to handle and it will slide into place easily. The just leave the door closed for about an hour to allow the new gasket to form up and hold into place.
Good luck
