Question about Nikon Coolpix 4600 Digital Camera
Pauses between takes
My Nikon 4600 camera pauses between takes . When you take a photo you can't take another one straight away. The screen goes blank for a few seconds so you have to wait inbetween shots.
Posted by catherineole on
Anonymous
    New Friend:
THE PAUSE TIME YOU ARE TELLING IS THE TIME TAKEN BY CAMERA TO READY AGAIN. YOU CAN NOTICE THAT WHEN YOU SHOOT PHOTO WITHOUT FLAST/OUTDOOR IN DAY TIME THAN IT DO NOT TAKES TIME PAUSE. WHEN CAMERA USES FLASH IT WILL TAKE TIME TO BE READY FOR NEXT SHOOT. IT IS NORMAL
Posted on Aug 20, 2010
Anonymous
    Brigadier General:
  • 11,967 Answers
Questions to ask yourself. Is the battery fully charged? Does the card have plenty of space or is it full of pictures that need to be downloaded? Is the card "cheap"? Is the card fast enough?(a class 4 or higher card will write faster)
Posted on May 19, 2010
1helpful
4answers
Blank LCD screen taking pics
Try to reset the camera.
RESET
: Find the * QUAL and +/- * buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks and everything is back to normal.
2answers
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
1helpful
My Nikon Coolpix 4600 will take 1 photo, then refuses to take anymore unless it's turned off and then turned back on. When first turned on the flash and AF LEDs go on. After 1 photo is taken, the flash...
I visited a brick-and-mortar camera store and asked a repair specialist. There I learned that the problem with my camera is a firmware problem and not worth fixing. I'll throw away the camera and buy another $150 disposable camera.
Camera is on! but blank screen when i turn it on !
Does it actually work? Does it take pictures? It may be that "liveview" is off-that is the screen you normally view on when taking your photos. Try using it and then playing your photos back and check if its woking. A mate of mine had that problem last week and thought her camera was broken!
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Tech support
Hi, there is a very easy soln. to your problem.
When the camera is in shooting mode, just click the multi-selector( the round thing surrounding the OK key). the flash menu will be displayed in the screen. Either choose the auto flash(no.1) or anytimeflash(no.4) mode. the blinking hand will be gone and you will once again have superb photos. relax and enjoy.
1helpful
2answers
LCD Screen is Blank
twiddle the wheel at the back it fixed mine!!!
Nikon Coolpix 4600 Digital Camera Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
