ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
I own a Ir 5000 and i just started getting "tire tracks" on my copies and prints. They show up about the middle of the page running left to right on a portrait type document
Re: imageRUNNER 5000 Copier: I own a Ir 5000 and i just...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
enter service mode( * 28 * >copier>option>PO_cont> off> ok) and make copies if erroir code does not display, replace potential sensor.check dc controller.
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Check the ink case first . If it's not empty then pull it out and shake it strong [ not so strong ] . Then take a brush and wipe it . After that take a hair dryer and focus cold air on it for 5 minutes .
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
The all above models are same with minor change for speed You need model as your daily output requirement All models are heavy duty. you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
