Question about Shure PG24/PG58 Professional Microphone
I have the PG24/PG58 set-up. My problem is that when I use the mic even at very low volume on my mixer it sometimes makes A popping sound and shuts off.i tried diffrent channels/changed to diffrent alkaline batteries and still no change!!sometimes in the middle of an intro it will shut off and will not turn on maybe after A couple of mins....any help would be very appreciated..... thanks!!!!!
you can check the connection of the microphone to the mixer and other audio appliances connected because the microphone is of high senstivity .
Also do check your power socket where you connect the receiver of the microphone because if the socket is having a partial contact the receiver will goes off and take some minutes to come on.
if this has been check and the problem still persist then you require a skilled personnel to work on it or you take it to the manufacturer...
Posted on May 19, 2010
