After booting up my monitor it goes black. i have to turn it off and on quite a number of times in order to get it to stay on then there's no problem until i let it go into sleep mode or hibernation or turn my system off. Sometimes it can take a long time to get it to stay on. Windows xp Professional Service Pack 3 (build 2600) board: micro-star international co. Ltd MS-7185 1.0 Bus clock: 201 megahertz bios: Phoenix Technologies ltd 6.00 pg 08/24/2006 nvidia geforce 6800 gs [display adapter] viewsonic VA1930wm [monitor] (19.1"vis s QFP070426624 January 2007)
Does it do the same with other PC?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
www.fixyourmonitor.com andhttp://www.youtube.com/watch?v=9Q6_TgNJv...
Good Luck!
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
