Change light bulb in emerson MW8115SS
SOURCE: Emerson Microwave MW8115SS
First of all, since it's under warranty, I would call Emerson or a local servicer who repairs Emerson microwaves under warranty. You probably have a defective door switch or broken door switch mount.
SOURCE: Operating a microwave oven without a load
In principle no it is not hazardous. In practice however, unless the machine is clean to the point of sterile, small items in the microwave can absorb more energy than they would if a large item was in the machine also. This can produce some damage to the machine. manufacturers generally recommend not running microwaves empty. Why would you want to? If in doubt, just a cup of water would be more than adequate. it is not a good idea to modify a microwave oven in any way. Hope this helps :)
SOURCE: Emerson microwave light out
There is a way but.... you will have to remove outer cover generally held on with screws at rear and under microwave be sure the oven is unplugged and when you take cover off there is a capacitor in there thats holds a charge stored even when oven is unplugged so dont touch nothing except the light bulb would prefer if you dont have much electrical experience to take to repair shop or have someone do it who has a little electrical knowledge hope this helps
SOURCE: how to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: How many watts does Emerson MW8675W Microwave have?
From memory, they were about 675 watts? Most MW's are between 500 & 1000watts, from "those" days.
Testimonial: "Thanks man! Packages sometimes say cooking times are based on a microwave with 1100 w, so that explains a lot."
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
