2001 Mercury Cougar Logo
A
Anonymous Posted on May 17, 2010
2001 Cougar: the steering wheel is locked and i cannot start th...
The steering wheel is locked and i cannot start the car.
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jun 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
10926
Points
54
Turn the wheel one way or the other using lots of pressure while trying to gently turn the key
  • fdf62 Aug 30, 2011
    Its probably the brake lights, check the fuse to the brake lights or the bulbs. This car is built with a saftey system and if your brake lights don't work the system won't allow you to start the engine.
1helpful
My steering column is locked and wont let me start car
Turn the steering wheel hard to left or right and at the same time turn your key.. if the car was turned off with the wheels turned there my be some pressure on the column good luck.
I have a 2001 Mercury Cougar and the horn and cruise control stopped working at the same time. What could be the problem?
there is a contained loop of wire under the steering wheel called a clock spring. All of the steering wheel controls are wired through the clock spring. These wires can break causing your symptoms.
Check your fuse box for blown fuses.
http://www.ehow.com/how_4590533_replace-clockspring-mercury-cougar.html
2answers
Cougar 2001 V6 engine, shakes initially but it go away when the car picks up the speed? please assit
Sounds like you might need a tune-up fuel filter plugs wires an oil change air filter.Etc.
2helpful
2answers
I put th key in the ignition and it will not turn. Headlights come on, can't turn the wheels they are in a straight foward position.
Not a lot of info here. I am assuming you are saying you can't turn the key in the lock. If the steering wheel is under pressure (can happen even with the wheels straight ahead) the lock mechanism can be putting pressure on the key making it very hard for the ley to release the lock mechanism. Try pulling on the wheel in one direction and turning the key. If nothing, try turning the wheel the other direction and try turning the key. You may need to replace the lock mechanism. This usually involves being able to turn the key in the lock or having to drill the lock. You are probably going to need a locksmith for this one but at least that is cheaper than going to the BMW shop. Of course you are not completely free of BMW because if the locksmith has to punch the lock, you will need to get a replacement.
Feb 15, 2010 • 2001 BMW Z3
2helpful
How to remove the steering wheel fo a 2001 mercury cougar?
disconnect the battery so the air bag does not go off,
remove screws from under steering wheel,remove nut on shaft and use a puller to remove steering wheel.
1helpful
2answers
I have a 2001 cougar 4 cly. suts off when break is applied
check for shorts and bad or corroded connections
2001 ford focus steering is lock, how to unlock it? this is the third time it happened.is this serious?
When you try to start the car does the key seem stuck, not turning? Occasionally I have to turn the steering wheel just a little before the key will turn. Always try to straighten your front wheels when you park before turning off the car, this puts less strain on the locking part of the steering wheel and makes it easier to start the car next time. The serious part of a steering wheel is the air bag, do not try to disassemble the steering wheel yourself, you may want to take it to a mechanic you trust in case an interior part of your steering wheel needs replacing.
That's my guess.
3helpful
2answers
2001 mercury cougar steering wheel?
Don't listen to that guy!!!! you need to take the plastic cover behind the steering wheel. there are two bolts holding the air bag in t30 (torx) then the air bag falls right off. then the steering wheel is held in by a 15 mm head bolt.
Warning: make sure battery is disconnected for at least 30 min before you mess with the air bag connector
Cant locate fuse box in 2001 cougar
have u looked under the steering wheel or under the hood if u have call a ford dealer and ask them
Whining noise
Your power steering pump is shot! Do not drive this car!!!
Your best bet is get one from the wreckers and have it installed. Frankster016
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
