Question about Water Heaters
Hot water wont get hot... - Water Heaters
Randy Marshall
  • 349 Answers
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
Posted on May 20, 2010
Hot water runs but heating wont. Pump continously overunning.
What do you mean when you say that 'hot water runs but heating won't' ? Do you mean that water is coming out of the hot water faucet, but that it is cold? When you say pump continuously overrunning, what pump and what do you mean by overrunning? I would like to help you, but I'm not sure what you are asking. Also, is this a water heater, or a boiler?
May 26, 2016 | Water Water Heaters
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
PowerStar. Model 45-557701 tankless water heater water wont get hot...it slowly quit getting the water hot
Hot Water Hot to Cold And back. I had that problem for 2 years. I had a very large shower head from the time I installed the tank-less hot water heater and the water temp would change from one extreme to another. Over time my shower head had stopped working as well as it did so I bought a smaller shower head and installed it and amazingly my water temperature quit changing temperature. I now turn my water to what temp I want and it stays there. It's been working correctly for 6 months now ... until yesterday and it quit working completely which is the reason I'm on here. lol
Jan 07, 2010 | Bosch & Tankless LP Hot Water Heater
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Water Heaters Logo
295 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
