Turn television on, and it turns itself off after a few seconds.
  • Anonymous May 19, 2010
    I inserted a VHS cassette into my television, and it ran for a while and then it turned itself off. It will turn on again, but only for a few seconds, then it turns off again. The tape will not eject. It is a Zenith model # TVSC2040F Manufactured September 2000 V
Jacques Marin
  • 566 Answers
Hi dustmop
I`m going to help you with your tv but first;
Can you give me your tv`s brand name and model number?
Posted on May 19, 2010
  • Jacques Marin
    Jacques Marin May 19, 2010
    Darn, forgot to open the full view again.
    Got the model number now.
    Anyway for what its worth and for free;
    The tape stuck inside is the reason the tv shuts off.
    Somebody`s going to have to open the set and remove that tape,vcr is defect.
    G`day
Shahid Electronics
  • 10,594 Answers
Let me know model number and brand of your tv to find out possible reason of its shut down.
Model number and brand info would be written at rear of tv.
Thanks.
  • 3 more comments
    Zenith Model # TVSC2040F
  • Shahid Electronics
    Shahid Electronics May 19, 2010
    How old is this tv?
    It has the year 2000 right below the model #
    I'm sorry, it says: manufactured September 2000 V to the right of the model #
    Thanks for info,
    It seems there are few cold/ dry solder connections/ joints in deflection circuit on main board.
    Please check main board for cold soldering joints and re-solder them to fix the issue.
My sharp LCD tv won't turn on,it goes off after a few seconds.
Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
Mar 13, 2013 | Televison & Video
Olevia tv shuts off by itself
Likely the main board and most of these sets there are few or no boards available.
Sep 01, 2012 | Syntax Olevia 527-S11 Television
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
When I turn on my television, the picture is bright white and it is hard to make out any figures on the screen for a few seconds, then the TV shuts off itself, the little red light will go off and it will...
HI, thank you for visit fixya.
Do you have two possibles solutions:
1.--Vertical IC and capacitors need be replace.
2..-- Convergence IC's is defective, need be replace.
Disconnect convergence plugs ( wires go to yoke) and turn the tv, see if any changes happenings.
Any question, I will be here, Thank you
Nov 11, 2009 | Toshiba 57H82 57" Rear Projection...
I turn the tv on and after a few seconds it shuts itself back off again. At that point I can't turn it back on until I unplug it and plug it back in. However, when I turn it back on it will again turn...
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
Oct 18, 2009 | Sharp 27K-S100 TV
The TV turns on and off after a few seconds and repeats itself.
There could be quite a few things that would cause the set not to power up. I dont have the service manual, however you can get a copy of the service manual at the following link for your model. As thats the only proper way to be able to check for the proper voltages to determine whats wrong with the set.
Heres the link.
http://servicemanuals.vstore.ca/
Nov 26, 2008 | Samsung HCL652W 65" Rear Projection...
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Television keeps turning itself off.
There are two integrated circuits called convergence amplifiers , they need to be replaced. this is a common failure on this model. the cost to replace with parts is around 250.00 dls depending on the tech. if you need more help let know thanks
Jun 14, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
