Freezers Logo
Question about Freezers
Door was left very slightly open. reclosed but so...
Door was left very slightly open. Reclosed but some contents not completely frozen after 5 days. Emptied and defrosted slight frost at top of door. Turned on and seems ok but was making a loud gurgling sound on closing door again. Went away after few seconds.
Anonymous
    New Friend:
  • 30 Answers
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
Posted on May 19, 2010
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
1helpful
Freezer door left open will it work again?
yes it must be shut off and completely defrosted.with doors left open it usually takes about 2 days. what happened if you look at the back wall in the freezer from the inside you will see a bunch of ice and there is more behind that panel you are looking at. it froze up the coils so that no air will get through them. good luck rich
Frigidaire freezer making noises
evaporator is probably frozen up
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
7helpful
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 • Freezers
The temperature is increasing and even when put on 'super freeze', the temperature is not increasing just slowly increasing. The model number is 7462SNH1 Please can you give any idea of a fix. A couple of...
fully defrost unit with door open.do not use hot water.
load up with cold food and switch on the unit will take upto 24hrs to reach normal.poss cause ice around coils ...
Feb 11, 2010 • Freezers
4helpful
Whirlpool AFB126/H/AL Freezer - Defrosting & Refrosting
Hi. I am Kelly and welcome to FixYa. Here is the real question..... Is the food staying frozen?
Freezers usually defrost 3 times a day (8 hr intervals) Some as often as 4 times a day. The freezer use concept is that it is not opened more than 3 times a day. (Yes there will be more times than that any given week)
Having said all of that.... some things to look at.
1. Check the door seal for any signs of tears... grease... collapse...
2. Make sure there are no gaps in the door or between the closed door and the seal.
3. Many people don't check this one... but make sure it is level. An un-level freezer can cause the door seal not to function correctly.
Now if your saying that the food is actually defrosting... then there are a few other things that can cause that.
A. Sticking / defective Defrost timer
B. Defrost element is not heating and the freezer goes through a VERY long defrost cycle as the contents have to reach 60 Deg F for the 60 Deg bi-metal thermostat to close and advance the defrost timer to start the compressor.
C. Intermittent operation of the 60 Deg thermostat
I hope this clears things up a bit for you.
Thanks for using FixYa.
Kelly
Feb 10, 2010 • Freezers
7helpful
Your fridge should be fine, if you have surges that frequently getting a whole house surge protection package would make alot of sense. Surges are especially damaging to electronic circuits found in TV's computers, cell phones, answering machines aell frankly in just about everything. Well worth the charge.
May 22, 2009 • Freezers
Top Freezers Experts
Marvin
Marvin
Gil Shultz
Are you a Freezer Expert? Answer questions, earn points and help others
