We have a ge dishwasher and it stopped draining yesterday and when we took out the filter it was filled with mold. The machine also makes sounds during the cycle
Re: We have a ge dishwasher and it stopped draining...
If theres mold it will also be in the pipes use a strong bleach with boiling water this should help to unbloke Very careful with bleach and boiling water they do react (bubbling).
Hi Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance. Daniel
GE dishwashers will have a sumpentrance screen ( #4 ) that should beremoved and checked for any gookus, see 1 or 2 screws on the cover top, which isbehind the lower spray arm. Almost all ( some newer GE dishwashers have a separatedrain pump and motor - but for our purpose, we will talk about the mostcommon GE dishwashers ) GE dishwashers have a drainsolenoid ( #1 ) that can fail and stopthe draining. If the solenoid cannot pull in the silver plunger, the drain portwill not open to allow the motor and pump assembly to drain the water out. Thesolenoid can be ohmedwith an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GEdishwashers have a selfclean filter ( #3 ) inside at the back.The draining water must pass through a plunger in the self clean filter body.This can get clogged up, or the plunger may twist and distort and not allow thedraining water to get past. The filter can be removed from the inside and theplunger will twist out of the self cleaning body for testing/checking. Next obstaclefor the draining water in the backflush valve ( #2 ). This valve can twistor distort and block the water flow as well. The drain port will need to beaccessed to check this flapper valve, the drain port will untwist from the selfclean filter body. All hoses in-between the items mentioned above and the drainhose itself all the way to the house plumbing should be checked forrestrictions.
restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water
falls down the back of the tub and into the filter area. The water comes through
the filter and back into the tub. During the wash and rinse periods all ( we
hope! ) the water will pass through the filter. The soil will settle into the
collection chamber and is held there. When the dishwasher goes into the pump out
mode the water in the sump is pumped through the collection chamber. This closes
the piston valve to the inside of the tub. The pump flushes the collection
chamber of all the food soil and pumps it down the drain. A check valve is
located in the drain line port. This valve allows the water to flow in the drain
direction only and prevents the water from coming back into the tub. The drain
line check valve must close in the back flow direction or the piston valve in
the collection chamber may not reopen into the tub after the pump out is
complete. Water should "fall" through the filter and go back into the
tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
