Canon PowerShot S5 IS Digital Camera Logo
A
Anonymous Posted on May 17, 2010
PowerShot® S5 IS Digital Camera: can i retrive deleted photos...
Can i retrive deleted photos
Linnn000
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Oct 28, 2013
Linnn000
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
3995
Points
15
Have you saved all these deleted photos on the inner memory card of this digital camera?
If you have, you can try my steps to see whether your deleted photos are recoverable:
Step1. Stop using this camera in case that any new file would rewrite your original photos.
Step2. Insert this camera to your computer and prepare to restore your photos.
Step3. Download a deleted photo recovery freeware to your computer and start to retrieve all your deleted photos back:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera. So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
Step4. Save and back up all the restored photos on a different memory card or drive in case of data recovery failure.
Note: Next time, you'd better back up all your important photos on different memory cards or drives in case of the similar data recovery problems.
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Oct 20, 2010
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1195969
Points
12483
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Shutter darkens on Canon S5 IS
U have a sick puppy on your hands. Hopefully, the camera is still under warranty. If not, it may not be cost effective to repair and replacement might be in order.
tip
Hi guys.. try NiMH rechargable battries with 2500 mAH or 2700 nAH. These...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
PICTURES GOT DELETED
Don't panic! You can recover all deleted pictures from your camera with the help of a good photo recovery tool. Launch Remo Recover on your laptop, connect your camera and get back deleted photos.
2answers
IS THERE ANYWAY TO RETRIVE DATA AFTER FORMATING
It's possible, plug your camera into your PC, and use a data recovery tool (such as Recuva) and hope for the best.
I want to delete all the pictures on my camera at once.
in play mode, press menu then goto erase and select erase all...
I hope this helps...
3answers
Lost pictures
check out cardrecovery.com
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
