Question about Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
Foodsaver Professional ii Turbo. Vacuum pump works but the heat seal does not heat/seal.
  • Anonymous Mar 15, 2014
    pulls a vacuum but wont stop pumping
Lee Eismann
    Novelist:
  • 88 Answers
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
I wish to install a new vacuum pump and a heat ribbon in my Foodsaver V 2240. Please tell me how I can acquire these parts. My food saver has worked well for years but I cannot afford to replace it and...
Hi ipreinecke...
Go to the following website and you can purchase spare parts there for your foodsaver.
Note: Once you are on the webpage, mouse over the "Support" tab for parts and a user manual,etc.
Please take time to rate me thumbs up
http://www.foodsaver.com/faqs.aspx?fgid=17
Sep 11, 2011 | Tilia FoodSaver V2240
Doesnt vacuum all the air out
Your Product Manual for the Tilia Foodsaver Food Sealer Vacuum V2240 is available here:
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Please review all the Tips for Successful Vacuum Packaging. You may find some pointers that will you remove all the air.
Mar 26, 2011 | Tilia FoodSaver V2240
The V2240 does not seal or vacuum at this particular step. The motor runs, the unit buttons are working but the vacuum, sealing action does not work..... Any ideas ..... And yes It was plugged in !
It's possible that liquid is getting into the sealer or the seal is dirty. Here's a link for a pdf that explains possible problems and solutions.
Dec 11, 2010 | Tilia FoodSaver V2240
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
Find a replacement light bulb for the foodsaver vaccuum sealer
Foodsaver has a toll free number that you might call to see if they can provide the part. 877-777-8042 is what is listed.
Apr 25, 2017 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
1,154 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Tom Chichester
Steve Butterworth
Terry
Terry
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
