Question about Sony VAIO VGN-NS240E/W Notebook
VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
I upgraded from Vista 32 bit to Windows 7 32 bit ( proffesional ) and now my fn + volume/ brightness keys don't work. i need to know which drivers I have to reinstall to get them to work.
  • Oliver Paredes
    Oliver Paredes Feb 23, 2014
    the instructions below work even on windows 8
Anonymous
  • 192 Answers
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
Posted on Sep 19, 2010
Need driver for sony vaio VGN-TZ27GN built in web...
There probably is not a driver specifically for Windows 7.
Usually you will have to use the one for Windows Vista.
Windows 7 is only a glorified version of Vista anyway.
Go here:Drivers
Select the Downloads tab, then select the operating system.
If you have 32 bit Win 7 then select the 32 bit Vista.
If you have home premium then select the same for Vista.
In the next drop down menu select Original Driver.
There is one for Vista called camera module driver
Feb 08, 2012 | Sony VAIO VGN-AR230G Notebook
Hi, im using vgn cr23g. i upgraded- the ram from 1GB to 4GB. Then i upgraded to Vista (Service pack 1) as advised by Windows 7 Upgrade Advisor. Now i want to upgrade My OS from 32-bit Vista to 64-bit...
I have checked the specs of your PC notebook, I can see that you can upgrade the OS of your notebook to windows 7, because your PC passed the requirements for the windows 7 OS.
I hope you have a great day.
Jul 03, 2011 | Computers & Internet
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
May 14, 2011 | Sony VAIO VGN-CR220E/P Notebook
I installed windows 7 home basic 32 bit .. sony vaio vgn cr23g was pre loaded with windows vista .. my webcam is not working!!! plz help
Try install the WEBCAM driver for you Sony VAIO found here:
http://b2b.sony.com/b2bMicrosites/landingpage/vaio_drivers/download_vaio_drivers.html
Feb 28, 2011 | Sony VAIO Notebook
I have a sony vaio vgn-sz491n. i have loaded windows 7 professional, 64bit onto it. in the device manager, it shows that a driver for a mass storage controller is missing. where can i find this...
Most likely missing a driver for SD/MC card reader
The problem is that Sony doesnt offer drivers for 64-bit windows so the other 32-bit drivers will not be compatible.
You have the options to install the windows versions supported by sony from esupport.sony.com (Vista or XP)
Or try installing windows 7 32-bit and installing the missing drivers from esupport (Vista section) as usually they are compatible.
If the driver is still missing you will need to update the driver from device manager (previously installed from esupport) and then select to browse or select a location, which will be %temp% or what is the same the temp folder for your account C\users\your_user_name\appdata\temp. This folder is usually hidden but it will work if you just type %temp%
Feb 14, 2011 | Sony VGN-SZ491N/X PC Notebook
Can i change the video card on a vaio VGN-NS240E? I have integrated video but would like to upgrade to something that can handle games. Anyone know how?
I'm sorry. It is not possible to upgrade the Inbuilt Video card. However, the Computer is shipped with the Express Card/54 slot. You can contact your nearest favorite dealer to get the Express Card slot supported Video card and install in the Computer. This improves the Graphic performance.
May 12, 2010 | Sony VAIO VGN-NS240E/W Notebook
FROM WHERE CAN I GET WIN.7 DRIVERS FOR SONY VAIO VGN-N250E
As if now windows 7 drivers are not available but you dont have to worry because Basic system functionality should be automatically enabled with the drivers included within the Windows 7 operating system.
However, if one of the drivers that came with the operating system does not work with your system, you can try installing the Windows Vista version of the driver provided by Sony for your model. Many of the Windows Vista drivers are compatible with Windows 7 based on current testing. Make sure you choose the bit version (32-bit or 64-bit) that matches your version of Windows 7.
For for driver download visit this website :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN250E
For information about windows 7 upgrade visit this website :
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=24
Mar 23, 2010 | Sony VAIO VGN-N250E/B Notebook
Can i update vista home premium to windows 7 without any charges on vaio ns 240e
The free upgrade to windows 7 only applies to computers purchased within the last 6 months or so
Nov 19, 2009 | Sony VAIO VGN-NS240E/W Notebook
Sony VAIO VGN-NS240E/W Notebook Logo
1,218 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
