Konica Minolta bizhub 250 All-In-One Laser Printer Logo
A
Anonymous Posted on May 17, 2010
Bizhub 250 All-In-One Laser Printer: My bizhub c250 is going through a hub to a router....
My bizhub c250 is going through a hub to a router. I cannot print to the c250. I can ping the ip address and it sends and receive the 4 packets of info. What am I doing wrong???
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on May 19, 2010
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544902
Points
4088
Type in the ip address of the copier in your web browser. You should be able to log on to the web image monitor and even print a test page. If so you are 90% of the way there. Now go back to the printer setup screen in windows and click on the "port" tab then on configure port. Make sure the port ip address is the same as the copier and make sure the port number is 9100. Keep in mind that the ip address of the copier needs to match the ip address of your network for the first 3 sets of numbers. So if your network ip is 192.168.50.50 the copier would need to have an ip address of 192.168.50.xx
Good Luck and Thank You for using Fixya
Biz hub c250 code error
clean the rollers for that draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do I check toner levels in a Biz Hub C250?
It will tell you when they are low, but when you print does it not show you a picture of the levels?
1helpful
How can i share my konica minolta (bizhub 250) scanner?
Scanners do not lend themselves to sharing like a printer does, due to two way communication that is needed....
What works may or may not be available for your printer, but a printer that is NOT HOSTED, but rather a network printer is how you do it. Essentially the printer is hooked up to your router and EACH machine then needs full printer software installed, and then each machine can run all functions as if the printer was hooked up to that machine.
What year did the minolta 250 bizhubs come out
Domestic Introduction date for the Konica Minolta Bizhub 250 was October of 2005.
Thank You for using Fixya.
2answers
How to reset the transfer unit (fuse?), do you
search in youtube you will get there, what you want,
1helpful
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
6helpful
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
